tool:thickness_sander
tool:thickness_sander [2019/02/05 22:35] – mike | tool:thickness_sander [2023/02/02 15:29] – phillip_ma | ||
^ Brand | Delta | | ^ Brand | Delta | | ||
- | ^ Usage Restrictions | Members | + | ^ Usage Restrictions | Members |
^ Owner | Michael Kessler | ^ Owner | Michael Kessler | ||
Line 17: | Line 20: | ||
^ Value | $$$ | | ^ Value | $$$ | | ||
+ | * Update this wiki to help with onboarding usage. | ||
Line 41: | Line 50: | ||
- | ===== Maintenance Log ==== | + | Some tips: |
+ | * Start with a pass where you aren't sanding anything so that you know you aren't cutting too deep and progress it no more than a 16th of a turn. | ||
+ | ===== Manual ===== | ||
- | | Wiki entry created | + | | Wiki entry created |
| Dismandled | | Dismandled | ||
| Replaced with Delta | 2018 | Michael K. | | | Replaced with Delta | 2018 | Michael K. | | ||
+ | | Out of service for repair | 6 Jan, 2021 | Michael K. | | ||
+ | | Planned Removal | 30 Aug, 2021 | Michael K. | | ||
+ | | Planer Tuneup and trainers trained (phillip_m and yeungx) | January 2022 | Phillip M | | ||
+ | | Drive belt for sanding Drum replaced since it broke, Beveled gears controlling lift mechanism replaced with steel gears. | ||
+ | | Motor for the conveyor belt repaired. | ||
