tool:thickness_sander
tool:thickness_sander [2019/02/05 22:35] – mike | tool:thickness_sander [2021/01/07 19:28] – mike | ||
^ Brand | Delta | | ^ Brand | Delta | | ||
- | ^ Usage Restrictions | Members | + | ^ Usage Restrictions | Members |
^ Owner | Michael Kessler | ^ Owner | Michael Kessler | ||
Line 17: | Line 20: | ||
^ Value | $$$ | | ^ Value | $$$ | | ||
Line 40: | Line 48: | ||
+ | Some tips: | ||
+ | * Start with a pass where you aren't sanding anything so that you know you aren't cutting too deep and progress it no more than a quarter turn each time. | ||
Line 46: | Line 73: | ||
- | | Wiki entry created | + | | Wiki entry created |
| Dismandled | | Dismandled | ||
| Replaced with Delta | 2018 | Michael K. | | | Replaced with Delta | 2018 | Michael K. | | ||
+ | | Out of service for repair | 6 Jan, 2021 | Michael K. | |
