tool:thickness_sander
tool:thickness_sander [2019/02/05 22:34] – mike | tool:thickness_sander [2019/06/19 20:52] – colorcoded | ||
Line 7: | Line 7: | ||
^ Status | ^ Status | ||
- | ^ Hackable | + | ^ Hackable |
+ | ^ Brand | Delta | ||
^ Usage Restrictions | Members Only, WOOD ONLY | | ^ Usage Restrictions | Members Only, WOOD ONLY | | ||
^ Owner | Michael Kessler | ^ Owner | Michael Kessler | ||
Line 34: | Line 35: | ||
+ | Some tips: | ||
+ | * Start with a pass where you aren't sanding anything so that you know you aren't cutting too deep and progress it no more than a quarter turn each time. | ||
===== Maintenance Log ==== | ===== Maintenance Log ==== |
