tool:taig_cnc_mill:taig_tools
tool:taig_cnc_mill:taig_tools [2017/10/31 14:45] – created jdmc | tool:taig_cnc_mill:taig_tools [2019/04/07 00:17] (current) – ↷ Links adapted because of a move operation 46.229.168.154 | ||
- | [[tool: | + | ====== TAIG CNC Mill Tools ====== |
+ | This page lists information for common/ | ||
+ | |**Description** | **Type** | **Mfg** | **Material** | ||
+ | |1/4" CGS End Mill | Flat End Mill | CGS | Carbide | 2 |6700 rpm | | ||
+ | |1/16" 2F SE | Flat End Mill| Unknown | HSS | 2| 5000 rpm | | ||
+ | |3/16" 2F SE | Flat End Mill | MA FORD| HSS | 2| 5000 rpm | | ||
+ | |1/4"D x 50deg CHAMFER 2F | Spot Drill | Unknown | HSS | 2 | 5000 rpm | | ||
+ | |1/8" Flat Endmill | Flat End Mill | Unknown | HSS | 2 | 10500 rpm | | ||
+ | |1/32" Endmill | Flat End Mill | Unknown | HSS | 2 | 10500 rpm | | ||
+ | ===== Tool Sources ===== | ||
+ | <TBD> |
tool/taig_cnc_mill/taig_tools.txt · Last modified: 2019/04/07 00:17 by 46.229.168.154
