tool:table_saw
Next revision | Previous revisionNext revisionBoth sides next revision | ||
tool:table_saw [2017/07/25 01:32] – created mike | tool:table_saw [2020/12/03 17:03] – mike | ||
- | * **donor** = hekseskudd | + | * **donor** = [[http:// |
* **hackable** = No (See tips below) | * **hackable** = No (See tips below) | ||
- | * **model** = Rigid 2424 0 | + | * **model** = DeWalt dw746 |
- | * **serial #** = | + | * **serial #** = Please Fill This Out |
- | * **arrived** = Feb 2014 | + | * **arrived** = October 2017 |
* **does it work?** = Works | * **does it work?** = Works | ||
- | * **if it breaks** = Put a "broken& | + | * **if it breaks** = Put a "broken" |
- | * **contact** = Tyson Haverkort (ninetynein) | + | * **where** = In Workshop |
- | * **where** = Under workbench in the workshop | + | * * **value** = Valuable enough that we should treat it with the respect that it cannot be replaced. |
- | * **value** | + | |
+ | ====== Manual ====== | ||
Line 20: | Line 26: | ||
* Non-slip footware | * Non-slip footware | ||
__Optional: | __Optional: | ||
Line 27: | Line 34: | ||
+ | __Watch This:__ | ||
====== Safe Operation ====== | ====== Safe Operation ====== | ||
Line 75: | Line 85: | ||
- | | Assembled | + | | Arrived |
