tool:sherline_cnc_mill
tool:sherline_cnc_mill [2015/12/13 20:31] – Removed drill-press operation details lukecyca | tool:sherline_cnc_mill [2018/03/09 05:01] (current) – Added link to PCB milling with Sherline colorcoded | ||
Line 11: | Line 11: | ||
^ Arrival Date | June 2010 | | ^ Arrival Date | June 2010 | | ||
^ Location | ^ Location | ||
- | ^ Value | $2000 | | ||
+ | Forum thread: https:// | ||
+ | For regular mill's operation: | ||
+ | login: '' | ||
+ | password: '' | ||
+ | For administrative tasks only the '' | ||
Line 25: | Line 31: | ||
__Required: | __Required: | ||
- | * Clamping devices (apply liberally; better to have more clamps at moderate pressure than few at great pressure, to avoid damaging the T-slot) | + | * Clamping devices (apply |
* an experienced machine operator (if this is not you, you must get someone to help you!) | * an experienced machine operator (if this is not you, you must get someone to help you!) | ||
+ | * long hair must be tied back | ||
__Optional (but recommended): | __Optional (but recommended): | ||
Line 35: | Line 42: | ||
- | * Gloves (NEVER | + | * Gloves, loose clothing |
* Unclamped Material (can be thrown off the machine!) | * Unclamped Material (can be thrown off the machine!) | ||
- | ====== Safe Operation | + | ====== Safe Operation |
+ | ======= Startup ========== | ||
+ | * With the power disconnected, | ||
+ | * Connect power. | ||
+ | * Open the front door of the CNC cabinet to access the keyboard, mouse, axis power and PC power. | ||
+ | * Make sure axis power is set to off. | ||
+ | * Turn on the PC. | ||
+ | * login: '' | ||
+ | * password: '' | ||
+ | * Start LinxCNC | ||
+ | * Make sure the big red Emergency stop button is off (pulled out). | ||
+ | * Enable the axis power. | ||
+ | * verify that there are no loose wires and the machine appears to be in good working order | ||
+ | * handle any warning messages that LinuxCNC reports. | ||
+ | * Proceed with prep and cut. | ||
+ | TODO: FINISH THIS | ||
+ | ======= Shut down ========== | ||
+ | * Quit LinuxCNC | ||
+ | * Disable axis power | ||
+ | * Logout of linux with the " | ||
+ | * Wait for all systems to turn off | ||
+ | * Disconnect CNC | ||
+ | * Stow keyboard, mouse, and extension cord in CNC | ||
+ | * Remove your tool(s) from the chuck. | ||
+ | * Clean up the cutting leftovers. | ||
+ | ====== PCB Milling | ||
- | TODO | + | See [[PCB Milling With Sherline]]. |
====== Notes for later: ====== | ====== Notes for later: ====== | ||
- Machine zero, work zero and G28: https:// | - Machine zero, work zero and G28: https:// | ||
+ | - http:// | ||
+ | - Tool speed calculator: http:// | ||
- We have collets for 3mm, 4mm, 6mm and 1/8”, 3/16”, 1/4" shank end mills. | - We have collets for 3mm, 4mm, 6mm and 1/8”, 3/16”, 1/4" shank end mills. | ||
- We have a [[http:// | - We have a [[http:// | ||
- The upper e-stop button should work, but verify that it stops the mill before you begin any real operation. | - The upper e-stop button should work, but verify that it stops the mill before you begin any real operation. |
tool/sherline_cnc_mill.1450038676.txt.gz · Last modified: 2015/12/13 20:31 by lukecyca
