tool:sherline_cnc_mill
tool:sherline_cnc_mill [2015/11/17 22:21] – Adding notes from Slack discussion of current Sherline operational state bruce | tool:sherline_cnc_mill [2018/03/09 05:01] (current) – Added link to PCB milling with Sherline colorcoded | ||
+ | ====== Sherline 5000 CNC mill ====== | ||
^ Status | ^ Status | ||
Line 8: | Line 11: | ||
^ Arrival Date | June 2010 | | ^ Arrival Date | June 2010 | | ||
^ Location | ^ Location | ||
- | ^ Value | $2000 | | ||
+ | Forum thread: https:// | ||
+ | For regular mill's operation: | ||
+ | login: '' | ||
+ | password: '' | ||
+ | For administrative tasks only the '' | ||
Line 22: | Line 31: | ||
__Required: | __Required: | ||
- | * Clamping devices (apply liberally; better to have more clamps at moderate pressure than few at great pressure, to avoid damaging the T-slot) | + | * Clamping devices (apply |
* an experienced machine operator (if this is not you, you must get someone to help you!) | * an experienced machine operator (if this is not you, you must get someone to help you!) | ||
+ | * long hair must be tied back | ||
__Optional (but recommended): | __Optional (but recommended): | ||
Line 32: | Line 42: | ||
- | * Gloves (NEVER | + | * Gloves, loose clothing |
* Unclamped Material (can be thrown off the machine!) | * Unclamped Material (can be thrown off the machine!) | ||
- | ====== Safe Operation | + | ====== Safe Operation ====== |
- | __Description: | + | ======= Startup ========== |
- | The drill press comes in a floor or bench-mounted model. It has a motor driven head that has a chuck that accepts bits or cutters. It also has an adjustable table on which the work is mounted. It is operated by pulling a rotary lever that lowers | + | * With the power disconnected, |
+ | * Connect power. | ||
+ | * Open the front door of the CNC cabinet to access the keyboard, mouse, axis power and PC power. | ||
+ | * Make sure axis power is set to off. | ||
+ | * Turn on the PC. | ||
+ | * login: '' | ||
+ | * password: '' | ||
+ | * Start LinxCNC | ||
+ | * Make sure the big red Emergency stop button is off (pulled out). | ||
+ | * Enable | ||
+ | * verify that there are no loose wires and the machine appears to be in good working order | ||
+ | * handle any warning messages that LinuxCNC reports. | ||
+ | * Proceed with prep and cut. | ||
- | __Start With A Risk Assessment To Ensure A Safe Work Area:__ | + | TODO: FINISH THIS |
- | - A two foot perimeter around the drill press should be kept clear of people, debris and sawdust that impair traction or footing to avoid slips and falls. | + | |
- | - Safety glasses with side shields or a face shield must be worn. Hearing protection should be worn. | + | |
- | - Do not wear gloves or anything that would allow a hand, fingers or clothing to be wrapped around the revolving bit. | + | |
- | __Operational Safety Rules:__ | + | ======= Shut down ========== |
- | - Make sure the size of the bit is equal to or less than the capacity of the drill press. | + | |
- | - Center punch the drill-hole location into the stock. | + | |
- | - Insert bit into drill chuck and tighten with the chuck key. REMOVE CHUCK KEY FROM THE DRILL CHUCK BEFORE STARTING THE DRILL PRESS | + | |
- | - Use a clamp or vise to securely fasten the stock to the drill press table. Never attempt to handhold stock less than 3’ long while drilling. | + | |
- | - Support the underside of the stock to be drilled with a backer board secured to the drill press table. DO NOT DRILL INTO THE DRILL PRESS’ TABLE, except for the existing hole in the centre of the drill press table! | + | ====== PCB Milling ====== |
- | - Keep hands and fingers at least 3” from rotating drill bits. | + | See [[PCB Milling With Sherline]]. |
- | - When drilling deep holes, frequently raise the drill bit from the hole and use a chip brush to remove cuttings and allow the cool bit to cool down. | + | |
- | - If a drill bit binds, turn off the drill press and carefully turn drill chuck backwards by hand to free the drill bit. | + | |
- | - Never reach around or under a rotating drill bit or grab the chuck to stop a drill press. This can result in hand puncture or other serious injury. | + | |
- | - Turn the drill press off before looking up or walking away from the machine. | + | |
- | - Never stop the rotation of the drill chuck, spindle, or uncontrolled stock rotation when jammed on the bit with your hands or fingers. | + | |
- | - Don’t touch the drill bit and shavings since they are hot immediately after drilling. | + | |
- | - Always clean the work area in the machine upon completion of the milling task. Do not use your hands or blow the shavings, use a chip brush. | + | |
- | - When milling into metal use a coolant oil (WD-40 often works well) and use the appropriate speeds and feeds. Rags or chip brushes saturated with cutting oil should be disposed of in a fire can or outside in the dumpster. Never place oil saturated material in the interior garbage cans within the space! | + | |
====== Notes for later: ====== | ====== Notes for later: ====== | ||
- Machine zero, work zero and G28: https:// | - Machine zero, work zero and G28: https:// | ||
- | - Currently we have a collet | + | - http:// |
- | - Our clamping options are a bit minimal at the moment, that should be addressed soon as well. | + | - Tool speed calculator: http:// |
+ | - We have collets | ||
+ | - We have a [[http:// | ||
- The upper e-stop button should work, but verify that it stops the mill before you begin any real operation. | - The upper e-stop button should work, but verify that it stops the mill before you begin any real operation. | ||
tool/sherline_cnc_mill.1447798912.txt.gz · Last modified: 2015/12/12 14:31 (external edit)
