tool:sewing_machines [2019/03/29 19:04] – 00739 | tool:sewing_machines [2023/10/10 03:32] – elizabot | ||
Line 6: | Line 6: | ||
Older machines tend to have more solid metal parts and build, and can sew through tougher materials like denim, leather and multiple layers. | Older machines tend to have more solid metal parts and build, and can sew through tougher materials like denim, leather and multiple layers. | ||
- | **Sewing Machine | + | **Sewing Machine |
- | * Check what kind of needle is in the machine. [[sewing_needles|Different needles are for different fabric.]] If your needle is [[sewing_needles# | + | * // **Important note**// Please make sure that you have the needle all the way up before you remove the fabric. If the fabric doesn' |
- | * //It keeps jamming from the bottom// - Check that your bobbin is wound correctly and inserted in the right direction | + | * // **Important note**// Not all feet work on all sewing machines! |
- | * //I'm sewing but all my stitches fall out// - Did you run out of bobbin thread? | + | * //**My stitches are uneven / keep skipping**// |
- | * //Threads are too loose or pulling tight// - Check the tension dials and stitch length. | + | * //**It keeps jamming from the bottom**// - [[tool: |
- | * //I'm sewing but it won't go anywhere// - Check your stitch length and style, are you on a stretch stitch or fancy? | + | * //**I'm sewing but all my stitches fall out**// - Did you run out of bobbin thread? |
+ | * //**Threads are too loose or pulling tight**// - Check that your machine is threaded correctly. | ||
+ | * //**I'm sewing but it won't go anywhere**// - Check your stitch length and style, are you on a stretch stitch or fancy? Are you trying to sew with the presser foot up? | ||
Line 18: | Line 20: | ||
- | * Product Page: http:// | + | * [[http:// |
- | * Manual: | + | * [[http:// |
- | * Quick Reference: | + | * [[http:// |
Line 38: | Line 40: | ||
+ | * Repair receipt with warranty: {{: | ||
Line 57: | Line 60: | ||
Line 63: | Line 66: | ||
^ Value | $ | | ^ Value | $ | | ||
+ | ===== Kenmore Ultrastitch 6 ===== | ||
+ | ^ Owner | VHS | | ||
+ | ^ Value | $ | | ||
===== Singer 656G ===== | ===== Singer 656G ===== | ||
Line 72: | Line 91: | ||
* Manual: Not found, but possibly hard copy available at the space | * Manual: Not found, but possibly hard copy available at the space | ||
Line 79: | Line 98: | ||
+ | Videos about threading the " | ||
+ | There' | ||
===== Singer Stylist 478 ===== | ===== Singer Stylist 478 ===== | ||
- | * see manual | + | |
Line 95: | Line 116: | ||
====== VHS Sergers ====== | ====== VHS Sergers ====== | ||
===== Kenmore 3/4 Differential Feed ===== | ===== Kenmore 3/4 Differential Feed ===== | ||
+ | Davonna says this is her serger and she has taken it home. | ||
+ | <del> | ||
+ | This is the main serger set up on the craft table. By default it is set at a 4-thread safety stitch for general purpose woven and stretch fabrics. Feel free to change thread cone colours, but for 3-thread edging, use the Janome located on the workbench. | ||
- | {{ : | + | ^ Status |
- | ^ Status | + | |
Line 114: | Line 139: | ||
===== Janome MyLock 234D ===== | ===== Janome MyLock 234D ===== | ||
- | * Manual: http:// | ||
Line 131: | Line 155: | ||
+ | [[http:// | ||
+ | ===== Baby Lock Evolution ===== | ||
+ | Avy has taken her Baby Lock Evoluation home. | ||
+ | <del> | ||
+ | This is an 8-thread, self-threading overlocker. | ||
+ | ^ Value | $$$ | | ||
+ | ====== VHS Embroidery Machine ====== | ||
+ | ===== Brother PE 800 ===== | ||
+ | ===== Reliable Sewing Machines 4000SW walking foot ===== | ||
+ | ^ Usage Restrictions | Anyone with experience on domestic machines - watch your fingers! | | ||
+ | ^ Value | $$$$ | | ||
tool/sewing_machines.txt · Last modified: 2023/10/10 03:33 by elizabot
