tool:sewing_machines [2019/03/29 03:52] – 00739 | tool:sewing_machines [2023/10/10 03:33] (current) – elizabot | ||
====== VHS Sewing Machines ====== | ====== VHS Sewing Machines ====== | ||
- | VHS has the following | + | VHS has a variety of sewing |
+ | Newer machines are more accurate and have more complex functions | ||
+ | Older machines tend to have more solid metal parts and build, and can sew through tougher materials like denim, leather and multiple layers. | ||
+ | **Sewing Machine FAQ:** | ||
+ | * // **Important note**// Please make sure that you have the needle all the way up before you remove the fabric. If the fabric doesn' | ||
+ | * // **Important note**// Not all feet work on all sewing machines! | ||
+ | * //**My stitches are uneven / keep skipping**// | ||
+ | * //**It keeps jamming from the bottom**// - [[tool: | ||
+ | * //**Threads are too loose or pulling tight**// - Check that your machine is threaded correctly. Check the tension dials and stitch length. | ||
- | * Product Page: http:// | + | |
- | * Manual: | + | {{ : |
- | * Quick Reference: | + | |
+ | ^ Owner | VHS | | ||
+ | ^ Value | $$ | | ||
===== Janome 6019 ===== | ===== Janome 6019 ===== | ||
- | * Type: Quilting Sewing Machine | ||
- | * Instruction Manual: {{http:// | ||
- | ===== Singer 5805 C ===== | + | {{ : |
- | * Type: Stitch | + | ^ Status |
- | * Manual: | + | ^ Training |
- | * [[https:// | + | ^ Hackable |
- | * Donated by Miststlkr. | + | ^ Usage Restrictions | Anyone |
- | * {{http:// | + | ^ Owner | VHS | |
+ | * Type: Quilting | ||
+ | * [[http://janome.com/siteassets/support/manuals/ | ||
+ | * Repair receipt with warranty: | ||
- | Maintenance Log - Aug 20th | ||
- | Cleaned, Oiled and lithium grease on gears. | ||
- | Checked all Stitches. | ||
===== Kenmore Ultrastitch 12 ===== | ===== Kenmore Ultrastitch 12 ===== | ||
+ | ^ Value | $ | | ||
+ | ===== Kenmore Ultrastitch 6 ===== | ||
===== Singer 656G ===== | ===== Singer 656G ===== | ||
* Type: Slant Shank Sewing Machine | * Type: Slant Shank Sewing Machine | ||
* Manual: Not found, but possibly hard copy available at the space | * Manual: Not found, but possibly hard copy available at the space | ||
- | + | ^ Status | |
+ | Videos about threading the " | ||
+ | There' | ||
===== Singer Stylist 478 ===== | ===== Singer Stylist 478 ===== | ||
+ | ====== VHS Sergers ====== | ||
===== Kenmore 3/4 Differential Feed ===== | ===== Kenmore 3/4 Differential Feed ===== | ||
+ | Davonna says this is her serger and she has taken it home. | ||
- | {{:tool:kenmore34serger.jpg? | + | < |
+ | This is the main serger set up on the craft table. By default it is set at a 4-thread safety stitch for general purpose woven and stretch fabrics. Feel free to change thread cone colours, but for 3-thread edging, use the Janome located on the workbench. | ||
===== Janome MyLock 234D ===== | ===== Janome MyLock 234D ===== | ||
- | * Type: Serger | + | |
- | * Manual: http:// | + | {{ :tool: |
- | * Donated | + | |
- | {{:tool:janomemylock.jpg?direct&400 |}} | + | ^ Status |
+ | [[http:// | ||
+ | ===== Baby Lock Evolution ===== | ||
+ | Avy has taken her Baby Lock Evoluation home. | ||
+ | This is an 8-thread, self-threading overlocker. | ||
+ | ^ Value | $$$ | | ||
+ | ====== VHS Embroidery Machine ====== | ||
+ | ===== Brother PE 800 ===== | ||
+ | ===== Reliable Sewing Machines 4000SW walking foot ===== | ||
+ | ^ Usage Restrictions | Anyone with experience on domestic machines - watch your fingers! | | ||
+ | ^ Value | $$$$ | | ||
tool/sewing_machines.txt · Last modified: 2023/10/10 03:33 by elizabot
