tool:redsail_cm1080_laser_cutter [2016/03/24 06:58] – lbuchy | tool:redsail_cm1080_laser_cutter [2019/12/11 23:41] (current) – The materials being cut should not be lasing. thovthe | ||
Line 10: | Line 12: | ||
- | Anyone who wishes to use the laser cutter must be both a VHS member, and have completed a laser cutter training class (class dates are announced on [[http:// | ||
Line 27: | Line 40: | ||
+ | * Controller: [[http:// | ||
+ | * Chiller: [[http:// | ||
+ | * Input: AC 220V | ||
+ | * Current: 32mA max | ||
==== Tutorials ==== | ==== Tutorials ==== | ||
* [[tutorials: | * [[tutorials: | ||
- | * [[http:// | + | * [[http:// |
+ | ==== Possible upgrades ==== | ||
+ | * [[https:// |
tool/redsail_cm1080_laser_cutter.1458802736.txt.gz · Last modified: 2016/03/24 06:58 by lbuchy
