tool:redsail_cm1080_laser_cutter [2015/11/08 18:07] – miststlkr | tool:redsail_cm1080_laser_cutter [2024/04/16 04:48] (current) – Added stepper driver details ddq | ||
Line 10: | Line 12: | ||
Line 27: | Line 40: | ||
+ | * Input: AC 220V | ||
+ | * Current: 32mA max | ||
+ | * Input: DC 40V | ||
+ | * Motor current: 4A | ||
+ | * Steps/rev: 5000 | ||
+ | * Idle current: half | ||
- | * [[tutorials: | + | * [[tool: |
+ | ==== Tutorials ==== | ||
+ | * [[tutorials: | ||
+ | ==== Possible upgrades ==== | ||
+ | * [[https:// |
tool/redsail_cm1080_laser_cutter.1447006062.txt.gz · Last modified: 2015/12/12 14:31 (external edit)
