tool:redsail_cm1080_laser_cutter [2013/11/22 20:52] – jarrett | tool:redsail_cm1080_laser_cutter [2024/04/16 04:48] (current) – Added stepper driver details ddq | ||
+ | * Input: AC 220V | ||
+ | * Current: 32mA max | ||
+ | * Input: DC 40V | ||
+ | * Motor current: 4A | ||
+ | * Steps/rev: 5000 | ||
+ | * Idle current: half | ||
+ | ==== Tutorials ==== | ||
+ | * [[tutorials: | ||
- | | Fixed by LCC. | Nov 22, 2013 | LCC | | + | |
- | | Exhaust fan is broken | + | |
tool/redsail_cm1080_laser_cutter.1385153532.txt.gz · Last modified: 2015/12/12 14:31 (external edit)
