tool:pcb_milling_with_sherline
tool:pcb_milling_with_sherline [2018/03/09 05:17] – created colorcoded | tool:pcb_milling_with_sherline [2018/03/09 07:24] (current) – colorcoded | ||
Line 11: | Line 11: | ||
* Minimum size: 10 mil | * Minimum size: 10 mil | ||
- | Here is a design rule file for Eagle: | + | Here is a design rule file for Eagle: |
===== Generating Gerbers ===== | ===== Generating Gerbers ===== | ||
Line 21: | Line 21: | ||
====== Generating gcode ===== | ====== Generating gcode ===== | ||
- | Start the Sherline mill up as described on [[tool:Sherline mill]]. | + | Start the Sherline mill up as described on [[tool:sherline_cnc_mill]]. |
tool/pcb_milling_with_sherline.txt · Last modified: 2018/03/09 07:24 by colorcoded
