tool:pcb_mill
tool:pcb_mill [2018/12/05 07:29] – mike | tool:pcb_mill [2018/12/05 07:46] – mike | ||
Line 58: | Line 58: | ||
The driver will be a GRBL based Arduino+Driver Shield. | The driver will be a GRBL based Arduino+Driver Shield. | ||
https:// | https:// | ||
+ | ===== Configuration Documentation ===== | ||
+ | Mostly this setup was followed: | ||
+ | https:// | ||
+ | ====== Credentials ====== | ||
+ | There is no physical security for this device, therefore, the credentials are physically on the device. | ||
+ | ====== Service ====== | ||
+ | The web service is simply started with a crontab @reboot declaration as follows: | ||
+ | There is also a portmapping from 80 to 8000; cnc.js runs on 8000 locally and translates external requests from external 80 to 8000. | ||
tool/pcb_mill.txt · Last modified: 2018/12/05 07:46 by mike
