tool:oscillator_model_k8202_400v_ac_power_supply
Both sides previous revisionPrevious revision | Next revisionBoth sides next revision | ||
retirement:oscillator_model_k8202_400v_ac_power_supply [2018/02/03 16:54] – lukecyca | retirement:oscillator_model_k8202_400v_ac_power_supply [2018/02/03 16:54] – lukecyca | ||
Elgar Power Supplies 501A Specs | Elgar Power Supplies 501A Specs | ||
- | Output Voltage Ranges: 0-32, 0-130, 0-260 | + | * Output Voltage Ranges: 0-32, 0-130, 0-260 |
- | Output Frequency Range: 45-5,000 Hz. | + | * Output Frequency Range: 45-5,000 Hz. |
- | Output Power (VA): 500 | + | * Output Power (VA): 500 |
- | Input: 115VAC, 47 - 63Hz | + | * Input: 115VAC, 47 - 63Hz |
- | Dimensions: 7" H x 19" W x 17" D | + | * Dimensions: 7" H x 19" W x 17" D |
- | Weight: 100 lbs. | + | * Weight: 100 lbs. |
Manual: | Manual: |
tool/oscillator_model_k8202_400v_ac_power_supply.txt · Last modified: 2019/04/05 22:47 by 00739
