tool:mendel_max_3d_printer
Both sides previous revisionPrevious revision | Next revisionBoth sides next revision | ||
tool:mendel_max_3d_printer [2014/02/24 00:26] – 2014-02-22 update i-make-robots | tool:mendel_max_3d_printer [2014/02/24 01:38] – i-make-robots | ||
Line 20: | Line 20: | ||
- Nozzle is unblocked and reassembled. | - Nozzle is unblocked and reassembled. | ||
- PIDs for bed and nozzle appear to be wrong: they refuse to heat to the desired temperature. | - PIDs for bed and nozzle appear to be wrong: they refuse to heat to the desired temperature. | ||
- Bed needs to be re-levelled. | - Bed needs to be re-levelled. | ||
- extrusion rate needs to be recalculated. | - extrusion rate needs to be recalculated. | ||
- z height sensor is loose and should be tightened. | - z height sensor is loose and should be tightened. | ||
tool/mendel_max_3d_printer.txt · Last modified: 2015/12/12 14:31 by 127.0.0.1
