tool:manual_lathe
tool:manual_lathe [2017/07/09 21:07] – rsim | tool:manual_lathe [2019/12/16 21:51] – Put in belts used thovthe | ||
Line 4: | Line 4: | ||
- | ^ Owner | Family friend of John Craver. | + | ^ Owner | VHS | |
- | ^ Loan Status | ||
^ Location | ^ Location | ||
Line 15: | Line 14: | ||
- | There is a **mandatory** | + | There is a **mandatory** |
Line 32: | Line 31: | ||
===== Materials ===== | ===== Materials ===== | ||
- | Allowed | + | **Allowed** |
* Aluminum | * Aluminum | ||
* Steel | * Steel | ||
* Brass (with [[http:// | * Brass (with [[http:// | ||
* Delrin, ABS, PVC, etc (most plastics) | * Delrin, ABS, PVC, etc (most plastics) | ||
+ | * Titanium (**note:** special care is required as titanium may ignite when machined!) | ||
- | Banned | + | **Banned** |
* Wood | * Wood | ||
* Fibrous materials | * Fibrous materials | ||
Line 44: | Line 44: | ||
* Anything that creates dust or grit. | * Anything that creates dust or grit. | ||
* Pretty much anything that's not metal or plastic. | * Pretty much anything that's not metal or plastic. | ||
+ | ==== Cutting Speeds ==== | ||
Cutting speeds can be determined easily by using this {{: | Cutting speeds can be determined easily by using this {{: | ||
+ | When getting into hardened, tempered, or annealed steels along with carbide (necessary) cutters, cutting speeds and depths can be unpredictable when going for a high-quality finish, and experimentation may be required. The video [[https:// | ||
+ | ===== Helpful Links ===== | ||
===== Essential Tooling for a Personal Lathe Kit ===== | ===== Essential Tooling for a Personal Lathe Kit ===== | ||
Line 63: | Line 71: | ||
TODO | TODO | ||
+ | ==== Thomas L. ==== | ||
- | ===== Helpful Links ===== | + | [[http:// |
- | * [[http:// | + | [[http:// |
- | * [[https://qph.ec.quoracdn.net/main-qimg-d41f0ff2190e2501f7d518045398d233-c|Parts of a lathe]] | + | |
+ | The VHS lathe has a quick tool change, takes the common 250-1xx series AXA. [[https://www.amazon.ca/gp/ | ||
===== Maintenance Log ===== | ===== Maintenance Log ===== | ||
+ | | V-Belts need replacing | Dec 2019 | | | ||
+ | | Motor changed & rewired | ??? - Nov 2019 | Bill & ??? | | ||
| Routine maintenance | Dec 2015 | Richard S. | | | Routine maintenance | Dec 2015 | Richard S. | | ||
| Wiki entry created | Nov 20, 2013 | Thomas L. | | | Wiki entry created | Nov 20, 2013 | Thomas L. | | ||
+ | ==== Maintenance Information ==== | ||
+ | == Belts: == | ||
+ | Spindle belt: B-31 | ||
+ | Motor Belt: B-28 | ||
+ | Source from auto parts stores, Grainger or Mcmaster. | ||
+ | [[https:// |
tool/manual_lathe.txt · Last modified: 2021/11/03 05:55 by rsim
