tool:laser_cutter:settings
tool:laser_cutter:settings [2018/06/05 05:47] – jdmc | tool:laser_cutter:settings [2022/09/27 01:05] (current) – david_neufeld | ||
Line 17: | Line 17: | ||
| Plywood 1/4" Birch | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$50 for 8' | | Plywood 1/4" Birch | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$50 for 8' | ||
- | | Plywood 1/8" Birch | Cut | | + | | Plywood 1/8" Birch | Cut | |
+ | | Plywood 1/8" Maple| Cut | 24 | 55 | 55 | 1 | | | ||
| Plywood 1/8" Birch | Etch | 80 | 28 | 28 | 1 | Deep etching, excellent for countersinking screw holes | | | Plywood 1/8" Birch | Etch | 80 | 28 | 28 | 1 | Deep etching, excellent for countersinking screw holes | | ||
| Plywood 4.2mm FSC Virola | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$20 for 8' | | Plywood 4.2mm FSC Virola | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$20 for 8' | ||
- | | Plywood 1/4" Flooring underlay | Cut | 12 | 60 | 60 | 1 | From Home Depot ~$9 for 4' | + | | Plywood 1/4" Flooring underlay | Cut | 12 | 60 | 60 | 1 | From Home Depot ~$9 for 4' |
===== Plastics ===== | ===== Plastics ===== | ||
- | ^ Material ^ Mode ^ Speed ^ Power ^ Corner Power ^ Passes ^ Notes ^ | + | ^ Material ^ Mode ^ Speed ^ Power ^ Corner Power ^ Passes ^ Notes ^ |
| Acrylic - 1/ | | Acrylic - 1/ | ||
- | | Polypropylene (0.75mm) | Cut | 30 | 50 | 45 | 1 | From Yoko-yaya, ideal for painting stencils (John) | | + | | Acrylic - 4.5mm | Cut | 23 | 50 | 50 | 1 | |
- | | EVA Foam (very thin, < 4mm) | Cut | | | | 1 | Michaels | | + | | Polypropylene (0.75mm) | Cut | 30 | 50 | 45 | 1 | From Yoko-yaya, ideal for painting stencils (John) | |
- | | EVA Foam (thin, ~1/ | + | | EVA Foam (very thin, < 4mm) | Cut | | | | 1 | Michaels | |
+ | | EVA Foam (thin, ~1/ | ||
| EVA Foam (thick, 1/2" floor mats) | Cut | 30 | 50 | 50 | 1 | Canadian Tire, Home Depot, etc. | | | EVA Foam (thick, 1/2" floor mats) | Cut | 30 | 50 | 50 | 1 | Canadian Tire, Home Depot, etc. | | ||
- | | PET/PETG | Cut | | | | 1 | | | + | | PET/ |
- | | Kapton Polyimide Film | | | | | | [[http:// | + | | PET/PETG (1/ |
+ | | Kapton Polyimide Film | | | | | | [[http:// | ||
| Styrene - 2mm | Cut | | | | 1 | 2mm white styrene sheet from hobby stores | | Styrene - 2mm | Cut | | | | 1 | 2mm white styrene sheet from hobby stores | ||
===== Fabric ===== | ===== Fabric ===== | ||
- | | Leather | Cut | | | | 1 | Leather from Dressew scrap bin (Paul) | + | | Leather |
- | | Felt | Cut | | + | | Felt | Cut | |
===== Other ===== | ===== Other ===== | ||
+ | | Application Tape | | | | | | Small amounts used for masking | | ||
+ | | Painters Tape | | | | | | Small amounts used for masking | | ||
+ | | Laserbond100 Marking Spray | | | | | | Aerosol propellants are nasty - ensure the coating has fully dried before lasering | | ||
+ | | Cermark 6000 Marking Spray | | | | | | Aerosol propellants are nasty - ensure the coating has fully dried before lasering | | ||
===== Etch Only ===== | ===== Etch Only ===== | ||
Line 64: | Line 72: | ||
| Fiberglass | Hazardous dust | | | Fiberglass | Hazardous dust | | ||
| Printed Circuit board | Hazardous dust | | | Printed Circuit board | Hazardous dust | | ||
+ | | Chrome Tanned Leather | Toxic/ | ||
+ | ====== Provisionally Approved ====== | ||
+ | The following materials have been provisionally approved by the Laser Cutter Committee for testing: | ||
+ | ^ Material ^ Mode ^ Speed ^ Power ^ Corner Power ^ Passes ^ Notes ^ | ||
+ | | Cork | Cut | TBD | TBD | TBD | TBD | | ||
+ | | Cork | Etch | TBD | TBD | TBD | TBD | | ||
====== FURTHER INFORMATION ====== | ====== FURTHER INFORMATION ====== |
tool/laser_cutter/settings.1528177651.txt.gz · Last modified: 2018/06/05 05:47 by jdmc
