tool:laser_cutter:settings
tool:laser_cutter:settings [2013/12/18 00:02] – jarrett | tool:laser_cutter:settings [2022/09/27 01:05] (current) – david_neufeld | ||
- | ====== Laser Cutter | + | ====== |
+ | Only the following materials may be cut or engraved on the [[tool: | ||
+ | Settings are provided here as a starting point. Always do test cuts to find optimal settings. | ||
- | ^ Behaviour | + | ===== Papers ===== |
- | | Cut | Mode=Cut in software, will pierce material | + | ^ Material ^ Mode ^ Speed ^ Power ^ Corner Power ^ Passes ^ Notes ^ |
- | | Etch | + | | Card Stock | Etch | 35 | 10 | 10 | 1 | | |
- | | Raster | + | | Card Stock | Cut | 35 | 35 | 25 | 1 | |
+ | | Heavy paper | Cut | 200 | 20 | 20 | 1 | Worked barely; long straight cuts needed multiple passes, and a few corners were missed. Use lower speed | | ||
+ | | Picture Matting | Cut | 40 | 50 | 40 | 1 | | | ||
+ | | Corrugated Cardboard | | | | | | | | ||
- | This is fairly outdated and shouldn' | + | ===== Woods ===== |
+ | Please avoid the use of woods with any water, sap, or a high proportion of glue. They quickly clog the filtration system and leave substantial residue on the laser cutter. | ||
+ | ^ Material ^ Mode ^ Speed ^ Power ^ Corner Power ^ Passes ^ Notes ^ | ||
+ | | Plywood 1/4" Birch | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$50 for 8' | ||
+ | | Plywood 1/8" Birch | Cut | 24 | 55 | 55 | 1 | From Windsor Plywood ~$17 for 5' | ||
+ | | Plywood 1/8" Maple| Cut | 24 | 55 | 55 | 1 | | | ||
+ | | Plywood 1/8" Birch | Etch | 80 | 28 | 28 | 1 | Deep etching, excellent for countersinking screw holes | | ||
+ | | Plywood 4.2mm FSC Virola | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$20 for 8' | ||
+ | | Plywood 1/4" Flooring underlay | Cut | 12 | 60 | 60 | 1 | From Home Depot ~$9 for 4' | ||
+ | ===== Plastics ===== | ||
+ | | Acrylic - 1/ | ||
+ | | Acrylic - 4.5mm | Cut | 23 | 50 | 50 | 1 | | ||
+ | | Polypropylene (0.75mm) | Cut | 30 | 50 | 45 | 1 | From Yoko-yaya, ideal for painting stencils (John) | | ||
+ | | EVA Foam (very thin, < 4mm) | Cut | | | | 1 | Michaels | | ||
+ | | EVA Foam (thin, ~1/ | ||
+ | | EVA Foam (thick, 1/2" floor mats) | Cut | 30 | 50 | 50 | 1 | Canadian Tire, Home Depot, etc. | | ||
+ | | PET/PETG (e.g. Mylar(tm) ) | Cut | | | | 1 | | | ||
+ | | PET/PETG (1/ | ||
+ | | Kapton Polyimide Film | | | | | | [[http:// | ||
+ | | Styrene - 2mm | Cut | | | | 1 | 2mm white styrene sheet from hobby stores | ||
+ | ===== Fabric ===== | ||
+ | | Leather (Vegetable Tanned) | Cut | | | | 1 | | | ||
+ | | Felt | Cut | 100 | 25 | | 1 | | | ||
+ | ===== Other ===== | ||
+ | | Application Tape | | | | | | Small amounts used for masking | | ||
+ | | Painters Tape | | | | | | Small amounts used for masking | | ||
+ | | Laserbond100 Marking Spray | | | | | | Aerosol propellants are nasty - ensure the coating has fully dried before lasering | | ||
+ | | Cermark 6000 Marking Spray | | | | | | Aerosol propellants are nasty - ensure the coating has fully dried before lasering | | ||
+ | ===== Etch Only ===== | ||
+ | | Anodized Aluminum| Vector Etch | | | | 1 | | ||
+ | ====== Banned Materials ====== | ||
+ | The following is a non-exhaustive list of materials that must not be cut or engraved on the [[tool: | ||
- | ===== Banned Materials ===== | ||
^ Material ^ Reason ^ | ^ Material ^ Reason ^ | ||
| Wet or ' | | Wet or ' | ||
- | | MDF, Ply, and reconstructed wood | Clogs up filter BADLY | | + | | MDF, HDF, Ply, and reconstructed wood | Clogs up filter BADLY | |
| Coroplast | | Coroplast | ||
- | | Lexan/ | + | | Lexan/ |
| ABS | Dense black smoke and toxic fumes - cyanide and styrene gases | | | ABS | Dense black smoke and toxic fumes - cyanide and styrene gases | | ||
- | | PVC, Vynyl | Toxic and corrosive fumes - chlorine gas | | + | | PVC, Vinyl | Toxic and corrosive fumes - chlorine gas | |
+ | | Neoprene (polychloroprene) | Toxic and corrosive fumes - chlorine gas | | ||
| Foam core | Dense black smoke and toxic fumes - styrene gas (carcinogenic, | | Foam core | Dense black smoke and toxic fumes - styrene gas (carcinogenic, | ||
| Delrin | Toxic fumes - formaldehyde | | | Delrin | Toxic fumes - formaldehyde | | ||
+ | | Moleskine notebook covers | Toxic fumes - chlorine - See Polymer burnination link at bottom| | ||
+ | | Carbon Fiber | Hazardous dust | | ||
+ | | Fiberglass | Hazardous dust | | ||
+ | | Printed Circuit board | Hazardous dust | | ||
+ | | Chrome Tanned Leather | Toxic/ | ||
- | ===== Approved and Successful Material Settings ===== | ||
- | ** * = Please avoid the use of woods with any water, sap, or a high proportion of glue**. We're re-evaluating their use due to severely and VERY quickly clogging the filtration system and substantial residue being left on the laser cutter. | ||
- | ^ Material ^ Mode ^ Speed ^ Power ^ Corner Power ^ Passes ^ Notes ^ | ||
- | | Card Stock | Etch | 35 | 10 | 10 | 1 | N/A | | ||
- | | Card Stock | Cut | 35 | 35 | 25 | 1 | N/A | | ||
- | | Card Stock | Raster | ??? | ??? | ??? | 1 | N/A | | ||
- | | Heavy paper | Cut | 200 | 20 | 20 | 1 | Worked barely; long straight cuts needed multiple passes, and a few corners were missed. Use lower speed | | ||
- | | Picture Matting | Cut | 40 | 50 | 40 | 1 | N/A | | ||
- | | Acrylic - 1/ | ||
- | | * Wood (Hardboard 1/ | ||
- | | Leather | Cut | 50 | 35 | 100 | 1 | Leather from Dressew scrap bin (Paul) | | ||
- | | Polypropylene (0.75mm) | Cut | 30 | 50 | 45 | 1 | From Yoko-yaya, ideal for painting stencils (John) | | ||
- | | Plywood 1/4" Birch | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$50 for 8' | ||
- | | Plywood 1/8" Birch | Cut | 16 | 55 | 55 | 2 | From Windsor Plywood ~$17 for 5' | ||
- | | Plywood 4.2mm FSC Virola | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$20 for 8' | ||
- | | Plywood 1/4" Flooring underlay | Cut | 7 | 80 | 75 | 1 | From Home Depot ~$9 for 4' | ||
- | | EVA Foam (very thin, < ~4mm) | Cut | ??? | ??? | ??? | 1 | Michaels | | ||
- | | EVA Foam (thin, ~1/ | ||
- | | EVA Foam (thick, 1/2" floor mats) | Cut | ??? | ??? | ??? | 1 | Canadian Tire, Home Depot, etc. | | ||
+ | ====== Provisionally Approved ====== | ||
+ | The following materials have been provisionally approved by the Laser Cutter Committee for testing: | ||
- | ===== Failed Settings ===== | ||
- | | Acrylic - 1/ | + | | Cork | Cut | TBD | TBD | TBD | TBD | | |
- | | Hard Board - 1/ | + | | Cork | Etch | TBD | TBD | TBD | TBD | | |
- | ==== FURTHER INFORMATION ==== | + | ====== FURTHER INFORMATION |
Line 62: | Line 88: | ||
+ | * [[http:// |
tool/laser_cutter/settings.1387324932.txt.gz · Last modified: 2015/12/12 14:31 (external edit)
