tool:laser_cutter:settings
tool:laser_cutter:settings [2019/07/14 02:29] – add cork under provisional approval jdmc | tool:laser_cutter:settings [2021/10/13 07:27] – Added further information for cutting felt aibhlin_mowle | ||
Line 17: | Line 17: | ||
| Plywood 1/4" Birch | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$50 for 8' | | Plywood 1/4" Birch | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$50 for 8' | ||
- | | Plywood 1/8" Birch | Cut | | + | | Plywood 1/8" Birch | Cut | |
- | | Plywood 1/8" Maple| Cut | | + | | Plywood 1/8" Maple| Cut | |
| Plywood 1/8" Birch | Etch | 80 | 28 | 28 | 1 | Deep etching, excellent for countersinking screw holes | | | Plywood 1/8" Birch | Etch | 80 | 28 | 28 | 1 | Deep etching, excellent for countersinking screw holes | | ||
| Plywood 4.2mm FSC Virola | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$20 for 8' | | Plywood 4.2mm FSC Virola | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$20 for 8' | ||
Line 39: | Line 39: | ||
| Leather (Vegetable Tanned) | Cut | | | | 1 | | | | Leather (Vegetable Tanned) | Cut | | | | 1 | | | ||
- | | Felt | Cut | | + | | Felt | Cut | |
===== Other ===== | ===== Other ===== |
tool/laser_cutter/settings.txt · Last modified: 2022/09/27 01:05 by david_neufeld
