tool:laser_cutter:settings
tool:laser_cutter:settings [2022/09/21 05:52] – david_neufeld | tool:laser_cutter:settings [2022/09/27 01:05] (current) – david_neufeld | ||
Line 28: | Line 28: | ||
| Acrylic - 1/ | | Acrylic - 1/ | ||
- | | Acrylic - 4.5mm | Cut | + | | Acrylic - 4.5mm | Cut |
| Polypropylene (0.75mm) | Cut | 30 | 50 | 45 | 1 | From Yoko-yaya, ideal for painting stencils (John) | | | Polypropylene (0.75mm) | Cut | 30 | 50 | 45 | 1 | From Yoko-yaya, ideal for painting stencils (John) | | ||
| EVA Foam (very thin, < 4mm) | Cut | | | | 1 | Michaels | | | EVA Foam (very thin, < 4mm) | Cut | | | | 1 | Michaels | |
tool/laser_cutter/settings.txt · Last modified: 2022/09/27 01:05 by david_neufeld
