tool:laser_cutter:operation_manual [2017/10/06 00:08] – jdmc | tool:laser_cutter:operation_manual [2019/07/31 19:37] (current) – chad.leaman_gmail.com | ||
Line 29: | Line 29: | ||
The [[tool: | The [[tool: | ||
- | The laser cutter is a piece of industrial machinery. | + | The laser cutter is not a printer, it is not an appliance, and it is not a peripheral. It must be treated as such; a potentially very dangerous device. You must remain within 1 meter of the Emergency Stop button at all times. It must never be left unattended, even for a minute. Fires in laser cutters are very common, the operator must be ready at all times to extinguish a fire as soon as it occurs. |
- | One person had their entire shop burned down because they cut acrylic and left it. | + | "We know of four people who have had to essentially replace their laser cutting machine because it caught on fire unattended. |
+ | One person had their entire shop burned down because they cut acrylic and left it." | ||
**There is a zero-tolerance policy for leaving the laser cutter unattended while in operation. Laser cutter privileges will be revoked immediately.** | **There is a zero-tolerance policy for leaving the laser cutter unattended while in operation. Laser cutter privileges will be revoked immediately.** | ||
Line 116: | Line 117: | ||
If successful, your User profile will now list the linked account. | If successful, your User profile will now list the linked account. | ||
- | ===== OPERATING THE LASER CUTTER ===== | + | ====== OPERATING THE LASER CUTTER |
- | ==== Preparation ==== | + | ===== Preparation |
* Wake up or turn on the Laser Cutter Computer (it should be left on) | * Wake up or turn on the Laser Cutter Computer (it should be left on) | ||
Line 131: | Line 132: | ||
* Position additional fans to direct air into the space from the main doors | * Position additional fans to direct air into the space from the main doors | ||
- | ==== Authentication ==== | + | ===== Authentication |
The laser cutter has a software-controlled Laser Access System for restricting access to trained members and automatically controlling power to the laser and peripherals. The Laser Access System has an on/off switch and lights which indicate the status. | The laser cutter has a software-controlled Laser Access System for restricting access to trained members and automatically controlling power to the laser and peripherals. The Laser Access System has an on/off switch and lights which indicate the status. | ||
Line 154: | Line 155: | ||
**NOTE:** If you are using the laser cutter directly after another member, you can perform the authorization step as soon as they switch the system off. There is no need to wait for the system to power down. | **NOTE:** If you are using the laser cutter directly after another member, you can perform the authorization step as soon as they switch the system off. There is no need to wait for the system to power down. | ||
- | ==== System Power-up ==== | + | ===== System Power-up |
The Laser Access System will automatically turn on the Fume Extraction System, the Chiller, the Air Compressor, and the Laser Cutter. If the HVAC system in the space is currently running, the fan will be shut off. | The Laser Access System will automatically turn on the Fume Extraction System, the Chiller, the Air Compressor, and the Laser Cutter. If the HVAC system in the space is currently running, the fan will be shut off. | ||
+ | If the system is off, the power for the laser cutter is over by the fridge in the lounge area | ||
Be aware that when the Laser Cutter is first powered, the head and gantry will move to the home position automatically. | Be aware that when the Laser Cutter is first powered, the head and gantry will move to the home position automatically. | ||
Line 163: | Line 166: | ||
Once the laser is powered up, there are a number of steps required to setup a particular job. These include importing the design, setting up the cutting or etching operations, positioning the material, and adjusting the focus. | Once the laser is powered up, there are a number of steps required to setup a particular job. These include importing the design, setting up the cutting or etching operations, positioning the material, and adjusting the focus. | ||
- | ==== Import Design ==== | + | ===== Transfer and Import Design |
- | Importing a new design into LaserCAD | + | Designs |
- | ==== Setup Operations ==== | + | ===== Setup Operations |
Once you have imported a design, you need to setup one or more lasing operations (e.g. cut, etch). Simple designs may only have a single operation, while more complex designs can have many operations. It is necessary to indicate which parts of the design correspond to which operation, and to indicate in which order they should be performed. | Once you have imported a design, you need to setup one or more lasing operations (e.g. cut, etch). Simple designs may only have a single operation, while more complex designs can have many operations. It is necessary to indicate which parts of the design correspond to which operation, and to indicate in which order they should be performed. | ||
Line 217: | Line 224: | ||
Note: **Do not** touch the mirrors or lens of the laser cutter. If they are dirty, please discontinue use of the laser cutter immediately and let the Laser Cutter Committee know. Using the laser cutter with dirty mirrors or lenses could bake the dirt onto the glass and they will then need replacing! | Note: **Do not** touch the mirrors or lens of the laser cutter. If they are dirty, please discontinue use of the laser cutter immediately and let the Laser Cutter Committee know. Using the laser cutter with dirty mirrors or lenses could bake the dirt onto the glass and they will then need replacing! | ||
- | ==== Download job to Laser Cutter ==== | + | ===== Download job to Laser Cutter |
* In LaserCAD: | * In LaserCAD: | ||
- | * Click the Download button. This will open a dialog box. | + | * Click the Download button |
- | * Click Download. The job will be downloaded and the laser cutter will beep if successful. | + | * Click Download |
- | ==== Test Placement ==== | + | ===== Test Placement |
* Click Run Box. The laser head will move in a box at the maximum extents of the job. | * Click Run Box. The laser head will move in a box at the maximum extents of the job. | ||
* Be prepared to hit the Emergency Stop button is going to collide with the extent of the work bed or a clamp. | * Be prepared to hit the Emergency Stop button is going to collide with the extent of the work bed or a clamp. | ||
Line 247: | Line 254: | ||
===== Shutdown and Clean Up ===== | ===== Shutdown and Clean Up ===== | ||
- | * If you wish, save your files in the appropriate location. | + | * If you wish, save your files in the appropriate location. |
* Exit LaserCAD. | * Exit LaserCAD. | ||
* Toggle the Laser Access System switch to ' | * Toggle the Laser Access System switch to ' | ||
Line 266: | Line 274: | ||
* Setup your design as much as possible on a different computer | * Setup your design as much as possible on a different computer | ||
* Assign colors in your design file that correspond to different operations before you import to LaserCAD | * Assign colors in your design file that correspond to different operations before you import to LaserCAD | ||
+ | * Transfer designs to the Laser Cutter Computer using the Network Drive or USB stick, if possible. | ||
* Use simulation tool to estimate how long your cutting / engraving will take | * Use simulation tool to estimate how long your cutting / engraving will take | ||
* Separate engraves that are separated by whitespace into separate colors/ operations | * Separate engraves that are separated by whitespace into separate colors/ operations | ||
Line 277: | Line 286: | ||
* Dispose of unusable material in the garbage, breaking it up if necessary. | * Dispose of unusable material in the garbage, breaking it up if necessary. | ||
* Clean out the catchment tray | * Clean out the catchment tray | ||
===== Minimize Nasty Fumes ===== | ===== Minimize Nasty Fumes ===== |
tool/laser_cutter/operation_manual.1507248523.txt.gz · Last modified: 2017/10/06 00:08 by jdmc
