tool:laser_cutter:aligning
tool:laser_cutter:aligning [2015/12/12 14:31] – external edit 127.0.0.1tool:laser_cutter:aligning [2019/05/25 16:18] (current) jdmc
 +====== 2019-May-25: This is no longer up to date and requires revision. ======
 Sometimes the last stage of the laser focus system becomes misaligned.  This is usually due to vibrations from use over time. Sometimes the last stage of the laser focus system becomes misaligned.  This is usually due to vibrations from use over time.
tool/laser_cutter/aligning.txt · Last modified: 2019/05/25 16:18 by jdmc
