tool:jointer
tool:jointer [2019/02/18 01:45] – lbuchy | tool:jointer [2019/02/18 01:54] (current) – lbuchy | ||
Line 100: | Line 100: | ||
Once you are happy with where it is, tighten the jack screws. | Once you are happy with where it is, tighten the jack screws. | ||
Step 7: Repeat with the other 2 knives. | Step 7: Repeat with the other 2 knives. | ||
Step 8: Check again that all knives are still in the correct position. | Step 8: Check again that all knives are still in the correct position. |
tool/jointer.1550454355.txt.gz · Last modified: 2019/02/18 01:45 by lbuchy
