tool:hp_laserjet_3600n
tool:hp_laserjet_3600n [2015/11/10 22:22] – Updated with current location, ip, etc. lukecyca | tool:hp_laserjet_3600n [2019/04/23 21:17] (current) – 00739 | ||
====== HP Color LaserJet 3600n ====== | ====== HP Color LaserJet 3600n ====== | ||
- | | + | BROKEN |
- | * IP address: 172.16.0.12 | + | |
+ | ^ Owner | VHS | | ||
+ | ^ Arrival Date | Date | | ||
+ | ^ Value | $$ | | ||
+ | ====== This printer is broken and hackable if you wish ====== | ||
+ | * Hostname: vhs-printer01.vanhack.ca | ||
+ | * IP address: 172.16.0.8 | ||
* Drivers: [[http:// | * Drivers: [[http:// | ||
* Specs: [[http:// | * Specs: [[http:// | ||
Line 10: | Line 29: | ||
- Click the + sign to add a printer | - Click the + sign to add a printer | ||
- Select IP | - Select IP | ||
- | - Enter the Address: 172.16.0.12 and select the Protocal 'HP Jetdirect - Socket' | + | - Enter the Address: 172.16.0.8 and select the Protocal 'HP Jetdirect - Socket' |
- Use should populate with 'HP Color LaserJet 3600' | - Use should populate with 'HP Color LaserJet 3600' | ||
- Click ' | - Click ' | ||
Line 22: | Line 41: | ||
- Make sure ' | - Make sure ' | ||
- YOU MUST MAKE SURE Driver is set to ' | - YOU MUST MAKE SURE Driver is set to ' | ||
- | - For path enter < | + | - For path enter < |
- On the Printer Model Screen | - On the Printer Model Screen | ||
- On the next screen make sure it knows the model is a ' | - On the next screen make sure it knows the model is a ' |
tool/hp_laserjet_3600n.1447194175.txt.gz · Last modified: 2015/12/12 14:31 (external edit)
