tool:hp_laserjet_3600n
tool:hp_laserjet_3600n [2015/10/27 18:29] – laftho | tool:hp_laserjet_3600n [2019/04/23 21:17] (current) – 00739 | ||
- | =HP Color LaserJet | + | ====== HP Color LaserJet |
- | IP address is on the printer itself. There is also a QR code on the printer that you can scan to get more details. | + | BROKEN |
- | Drivers: | + | {{:tool:hplaserjet3600n.jpg?direct|}} |
- | http://h20564.www2.hp.com/ | + | |
- | Specs: | + | ^ Status |
+ | ^ Owner | VHS | | ||
+ | ^ Arrival Date | Date | | ||
+ | ^ Value | $$ | | ||
- | http:// | ||
+ | ====== This printer is broken and hackable if you wish ====== | ||
- | ---- | + | * Hostname: vhs-printer01.vanhack.ca |
- | =Old info= | + | * IP address: 172.16.0.8 |
+ | * Drivers: [[http:// | ||
+ | * Specs: [[http:// | ||
- | VHS was super lucky and generosity donated a HP LaserJet 3600n. | + | == Setup: |
- | ==You can print something from the Mame box== | + | |
- | The printer have been configured on the Mame box so if you need to print something quick from the internet that might be the simplest way. | + | |
- | - File -> Print | + | |
- | - Select HP-Color-LaserJet-3600n | + | |
- | ==Setting up the printer on your Mac== | + | |
- Go to System Preferences -> Printers | - Go to System Preferences -> Printers | ||
- Click the + sign to add a printer | - Click the + sign to add a printer | ||
- Select IP | - Select IP | ||
- | - Enter the Address: | + | - Enter the Address: |
- Use should populate with 'HP Color LaserJet 3600' | - Use should populate with 'HP Color LaserJet 3600' | ||
- Click ' | - Click ' | ||
- | ==Using Linux with KDE (You can likely figure out your linux from these directions)== | + | |
+ | == Setup: | ||
- Control Center -> Printers | - Control Center -> Printers | ||
- Select ' | - Select ' | ||
Line 34: | Line 41: | ||
- Make sure ' | - Make sure ' | ||
- YOU MUST MAKE SURE Driver is set to ' | - YOU MUST MAKE SURE Driver is set to ' | ||
- | - For path enter < | + | - For path enter < |
- On the Printer Model Screen | - On the Printer Model Screen | ||
- On the next screen make sure it knows the model is a ' | - On the next screen make sure it knows the model is a ' | ||
Line 41: | Line 48: | ||
- Make sure to select ' | - Make sure to select ' | ||
- | ==Drivers== | ||
- | You are able to download drivers from HP here: http:// | ||
- | ==Trouble Shooting== |
tool/hp_laserjet_3600n.1445970599.txt.gz · Last modified: 2015/12/12 14:31 (external edit)
