tool:green_manual_mill
tool:green_manual_mill [2017/07/25 00:02] – Added link to pdf manual for mill majicj | tool:green_manual_mill [2020/03/16 07:23] – billiam | ||
====== Manual Mill ====== | ====== Manual Mill ====== | ||
- | ^ Usage Restrictions | Members Only | | + | ^ Usage Restrictions | Members Only, only after VHS training / orientation |
^ Owner | (VHS or Name of proper owner) | ^ Owner | (VHS or Name of proper owner) | ||
Line 15: | Line 15: | ||
- | Always wear eye protection while using the mill. Do not use the mill if you do not know how to use this type of machine. If used improperly; workpieces | + | Always wear eye protection while using the mill. VHS-specific training / orientation is required. If used improperly, workpieces |
===== Specifications: | ===== Specifications: | ||
Line 31: | Line 31: | ||
===== Notes ===== | ===== Notes ===== | ||
- | To move mill head up and down (major vertical adjustment); | + | To move mill head up and down (major vertical adjustment); |
===== Axes ===== | ===== Axes ===== | ||
Line 41: | Line 41: | ||
===== Fixtures ===== | ===== Fixtures ===== | ||
- | We have a drilling | + | The 3.5" swivel |
We have a set of 1/2in T nuts + fingers + step blocks for the CNC mill that will also fit this mill. | We have a set of 1/2in T nuts + fingers + step blocks for the CNC mill that will also fit this mill. | ||
Line 47: | Line 47: | ||
===== Tooling ===== | ===== Tooling ===== | ||
- | - Drill Chuck | + | - Drill Chuck - at the moment, the only chuck key that fits is on the drill press in the Fab shop area. |
+ | - 2x Offset boring heads | ||
+ | - Fly cutter. Takes an HSS toolbit, ground to the correct profile | ||
+ | - 1/4, 3/8 and 1/2 collets. Used to hold end mills, fly cutters, and the small boring head | ||
+ | - 2.5" face mill. Needs to be replaced, as all the carbides are chipped, and are not available for purchase. Still works reasonably well | ||
+ | - Drift keys. USe to remove the tooling from the spindle. See document (pending) for use. | ||
- (many more in varying condition) | - (many more in varying condition) | ||
+ | - (Most) tooling is located in the red toolbox in the end of the (pending) work bench. | ||
===== Speeds & Feeds ===== | ===== Speeds & Feeds ===== | ||
Line 65: | Line 70: | ||
| Vice alined and bolted to table | Nov 26, 2013 | QuanaParker | | | Vice alined and bolted to table | Nov 26, 2013 | QuanaParker | | ||
| Tool/Work bench built {{:: | | Tool/Work bench built {{:: | ||
+ | | New drawbar, drift keys | Feb 2020 | Billiam | |
tool/green_manual_mill.txt · Last modified: 2023/02/09 20:43 by androidlx
