tool:function_generator
Both sides previous revisionPrevious revision | Last revisionBoth sides next revision | ||
tool:function_generator [2017/07/15 03:33] – jarrett | tool:function_generator [2017/07/24 23:56] – jarrett | ||
Line 22: | Line 22: | ||
- | Detailed specifications | + | The GFG-8216A is a Signal Function Generator with waveforms like sine, triangle, square, ramp, TTL and CMOS output. External voltage controlled frequency (VCF) function, duty cycle control with signal inversion capability, two-step (-20dBx2) and variable attenuator, built-in 6-digit counter with INT/EXT function up to 150MHz. |
- | Instructions on how to use the tool or links to references, pdf guide or something. This should | + | From [[https:// |
+ | A function generator is usually a piece of electronic test equipment | ||
+ | Function generators are used in the development, | ||
+ | For VHS in particular: | ||
+ | Find a BNC cable with alligator clips on one side. Not the oscilloscope leads! The proper cable can be dedicated for this function generator. It is not intended to drive high loads, like motors or LED strips - If it will blow an Arduino, it will destroy this gear. | ||
===== Maintenance Log ==== | ===== Maintenance Log ==== |
tool/function_generator.txt · Last modified: 2017/07/24 23:57 by jarrett
