tool:fpga-cluster
tool:fpga-cluster [2016/09/27 05:15] – jarrett | tool:fpga-cluster [2016/09/27 05:16] (current) – jarrett | ||
Line 22: | Line 22: | ||
There is an example set of software at: | There is an example set of software at: | ||
To run a test benchmark, run: | To run a test benchmark, run: | ||
java -cp InTraffic.jar Intraffic | java -cp InTraffic.jar Intraffic | ||
Line 32: | Line 34: | ||
In the example filesystem (path in previous section): | In the example filesystem (path in previous section): | ||
- | make should compile everything. | + | * make should compile everything. |
- | The .java file is host software source | + | |
- | The .jar file is the compiler host software | + | |
- | The .c file is the FX2 microcontroller firmware source | + | |
- | The .ihx is the compiler firmware, to be loaded by the host software | + | |
- | The fpga folder is the Verilog FPGA source | + | |
- | The .bit file is the compiler Verilog, to be loaded to the FPGA by the host software | + | |
tool/fpga-cluster.txt · Last modified: 2016/09/27 05:16 by jarrett
