tool:coffee_machine
tool:coffee_machine [2015/11/18 21:40] – jarrett | tool:coffee_machine [2021/05/01 15:32] (current) – to match the template johnc | ||
- | * **Quantity** = 1 | + | {{: |
- | * **owner** = ? | + | |
- | * **user certification required** = none | + | |
- | * **hackable** = No | + | |
- | * **model** = Saeco Odea Giro Plus | + | |
- | * **serial #** = ? | + | |
- | * **arrived** = ? | + | |
- | * **does it work?** = Works | + | |
- | * **if it breaks** = Put a & | + | |
- | * **contact** = | + | |
- | * **where** = kitchen | + | |
- | * **replacement value** = $600 | + | |
+ | Summary description of the tool and perhaps some notes about its existence! | ||
- | {{:tool:dsc_1969.jpg?300|}} | + | ^ Make & Model | Saeco Odea Giro Plus | |
+ | ^ Serial Number | ||
+ | ^ User Manual | ||
+ | ^ Owner | VHS | | ||
+ | ^ Arrival Date | 2015 or earlier? | ||
+ | ^ Value | $$ | | ||
+ | ===== Safety ===== | ||
+ | This should outline safety concerns and guidelines for the tool and its operation. | ||
+ | ===== Specifications ===== | ||
+ | Detailed specifications and references to information describing the tool. Strive for comprehensive! | ||
+ | ===== Tutorial ===== | ||
Make sure the water level is good (left panel), make sure waste bin is empty (right panel), place spare mug underneath nozzle, turn on. Machine will wake up, perform a self clean and expel some waste water first thing. | Make sure the water level is good (left panel), make sure waste bin is empty (right panel), place spare mug underneath nozzle, turn on. Machine will wake up, perform a self clean and expel some waste water first thing. | ||
Line 21: | Line 33: | ||
This is a very decent machine. | This is a very decent machine. | ||
+ | ===== Maintenance Log ==== | ||
+ | Any maintenance, | ||
+ | ^ Note ^ Date ^ Who ^ | ||
+ | | Wiki entry created | March 07, 2015 | John C. | |
tool/coffee_machine.txt · Last modified: 2021/05/01 15:32 by johnc
