tool [2020/09/29 18:16] – rob | tool [2024/08/13 03:42] (current) – Added Voron, removed unenclosed Prusa (no longer present) imagesurgery | ||
Line 17: | Line 16: | ||
- | ====== 3D Printing ====== | + | ====== 3D Printing |
- | | [[tool:DittoPro|Tinkerine Ditto Pro]] | [[tool: | + | | [[tool:voron_v2.4_voltron|Voron v2.4 350mm: Voltron]] | [[tool: |
| [[tool: | | [[tool: | ||
- | | [[tool:Prusai3B|Prusa i3 without case]] | [[tool: | + | | [[tool:DittoPro|Tinkerine Ditto Pro]] | [[tool: |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
- | ===== Casting | + | ^ Loaner 3D printers ^ Model ^ |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | ^ SLA Printers (Resin) ^ Model ^ | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | ====== Paint & Mess Room ====== | ||
^ Tools ^ Software | ^ Tools ^ Software | ||
Line 33: | Line 47: | ||
- | | [[tool:injection_molder|Injection Molder]] | | | + | | [[tool:vacuum_investment_casting_machine|Vacuum Investment Casting Machine]] | | |
Line 62: | Line 76: | ||
====== Electronics ====== | ====== Electronics ====== | ||
- | See: [[area:crafting|Crafting | + | See: [[area:electronics|Electronics |
^ Soldering Equipment | ^ Soldering Equipment | ||
| [[tool:Hot Air Station]] | [[tool: | | [[tool:Hot Air Station]] | [[tool: | ||
| [[tool:SMD Reflow Oven]] | [[tool: | | [[tool:SMD Reflow Oven]] | [[tool: | ||
- | | | [[tool: | + | | [[tool: |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | |.[[tool: | ||
Line 81: | Line 98: | ||
Line 104: | Line 121: | ||
+ | | [[tool: | ||
Line 114: | Line 132: | ||
^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^ | ^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^ | ||
- | | [[tool:Grizzly X3 4-Axis CNC Mill]] | [[tool: | + | | [[tool: |
- | | [[tool: | + | | CNC Mill " |
- | | [[tool:6040 CNC Mill]] | [[tool: | + | | [[tool:6040 CNC Mill|6040 CNC Mill " |
+ | | [[tool: | ||
+ | ====== Machine Shop ====== | ||
+ | See: [[area: | ||
+ | | [[tool: | ||
+ | | [[tool:manual_lathe|Metal Lathe]] | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | ====== Metal Shop ====== | ||
+ | | [[tool: | ||
+ | | [[tool:Bench Grinder]] | [[tool: | ||
- | | [[tool:Bench Grinder]] | | + | |
+ | | [[tool: | ||
+ | | [[tool:Heat Treating Oven]] | | ||
Line 145: | Line 189: | ||
| [[tool:Mini Wood (Pen) Lathe]] | [[tool: | | [[tool:Mini Wood (Pen) Lathe]] | [[tool: | ||
- | | [[tool: | ||
- | ===== Maintenance ===== | + | | [[tool: |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool:Air Compressor]] | | | ||
+ | | [[tool:Ace A-27 2HP Dust Extractor]] | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | ====== Maintenance/Facility ====== | ||
| [[hacks: | | [[hacks: | ||
+ | | [[tool: | ||
+ | | [[tools: | ||
====== Retirement ====== | ====== Retirement ====== | ||
[[area: | [[area: | ||
+ | | [[tool: | ||
tool.1601403398.txt.gz · Last modified: 2020/09/29 18:16 by rob
