tool [2019/04/07 20:06] – jarrett | tool [2024/03/06 06:16] (current) – phillip_ma | ||
Line 17: | Line 16: | ||
- | ====== 3D Printing ====== | + | ====== 3D Printing |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
- | ===== Casting ===== | + | ^ Loaner 3D printers ^ Model ^ |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
- | ^ Tools | + | ^ SLA Printers (Resin) ^ Model ^ |
+ | | [[tool: | ||
+ | ====== Paint & Mess Room ====== | ||
+ | ^ Tools | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
| [[tool: | | [[tool: | ||
- | | [[tool:injection_molder|Injection Molder]] | | | + | | [[tool:vacuum_investment_casting_machine|Vacuum Investment Casting Machine]] | | |
===== Sewing ===== | ===== Sewing ===== | ||
^ Machines ^ Tools ^ Supplies | ^ Machines ^ Tools ^ Supplies | ||
+ | | [[tool: | ||
===== Art ===== | ===== Art ===== | ||
- | ^ Machine ^ Tools ^ Supplies ^ | + | ^ Machine ^ Tools ^ Supplies |
- | | | Paint and sponge brushes | Paint (watercolour, | + | | | Paint and sponge brushes | Paint (watercolour, |
- | + | | | Exacto Knife kit | Ribbons | |
- | Stamps, Stamp ink pads, balsa wood, sidewalk chalk, pencil | + | |
Line 61: | Line 76: | ||
====== Electronics ====== | ====== Electronics ====== | ||
- | See: [[area:crafting|Crafting | + | See: [[area:electronics|Electronics |
^ Soldering Equipment | ^ Soldering Equipment | ||
- | | [[tool:Hot Air Station]] | [[tool: | + | | [[tool:Hot Air Station]] | [[tool: |
- | | [[tool:SMD Reflow Oven]] | [[tool: | + | | [[tool:SMD Reflow Oven]] | [[tool: |
- | | | [[tool: | + | | [[tool: |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | |.[[tool: | ||
====== The Hangout ====== | ====== The Hangout ====== | ||
- | | [[tool:server_rack|Server Rack]] | [[cleaningsupplies|Cleaning supplies]] | + | | [[tool:ultrasonic_cleaner|Ultrasonic Cleaner]] | [[tool: |
- | | [[tool:ultrasonic_cleaner|Ultrasonic Cleaner]] | | + | |
+ | | [[tool: | ||
+ | ===== Ops Room ===== | ||
+ | See: [[area: | ||
+ | ^ Servers ^ | ||
+ | | [[tool: | ||
+ | | [[infrastructure: | ||
+ | | [[tool: | ||
Line 94: | Line 120: | ||
+ | | [[tool: | ||
- | See: [[area:server_room|Server Room]] | + | See: [[area:lasercutroom|Laser Cutting Area]] |
- | ^ Servers | + | ^ Machines ^ Supplies |
- | | [[infrastructure:servers]] | | + | | [[tool:RedSail CM1080 Laser Cutter]] | [[area: |
- | | [[tool:fpga-cluster|FPGA Cluster]] | | + | | [[tool:laserfilter|Laser cutter filtration system]] | [[tool:laser_cutter: |
- | | [[tool:google server]] | | + | |
- | See: [[area:lasercutroom|Laser Cutting Area]] | + | See: [[area:metal_shop|Machine Shop]] |
- | ^ Machines ^ Supplies ^ | + | ^ Stationary |
- | | [[tool:RedSail CM1080 Laser Cutter]] | Laser cutter material storage | + | | [[tool:Sherline CNC Mill|Sherline]] | Shopvac (Shared with Machine Shop) | Hand Tools | Safety Equipment |
- | | Laser cutter filtration system | + | | [[tool: |
+ | | CNC Mill " | ||
+ | | [[tool:6040 CNC Mill|6040 CNC Mill " | ||
+ | | [[tool: | ||
- | ^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies | + | ^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^ |
- | | [[tool:Sherline CNC Mill]] | [[tool: | + | | [[tool:Green Manual |
- | | [[tool:Grizzly X3 4-Axis CNC Mill]] | [[tool: | + | | [[tool:manual_lathe|Metal Lathe]] | [[tool: |
- | | [[tool:Drill Press]] | [[tool:Bosch 4.5" Angle Grinder]] | | + | | [[tool: |
- | | [[tool: | + | ----- |
- | | [[tool:Bench Grinder]] | | + | ====== Metal Shop ====== |
+ | | [[tool: | ||
+ | | [[tool:Bench Grinder]] | [[tool:Cut-Off Saw]] | | Donated metal | | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool:Heat Treating Oven]] | | ||
Line 140: | Line 183: | ||
====== Woodworking ====== | ====== Woodworking ====== | ||
- | See: [[area:Woodworking|Woodwork Area]] | + | See: [[area:Wood_shop|Wood Shop]] |
- | | [[tool:Wood CNC]] | [[tool: | + | | [[tool:Wood CNC]] | [[tool: |
- | | [[tool:Bench Bandsaw]] | [[tool:Random-Orbit Palm Sander]] | | + | | [[tool:Bench Bandsaw]] | [[tool:18.0V Cordless Drill]] | [[tool:Norseman Drill Bit Set]] | | |
- | | [[tool:Mini Wood (Pen) Lathe]] | [[tool:Cut-Off Saw]] | | + | | [[tool:Mini Wood (Pen) Lathe]] | [[tool:Planer 40200H]] | |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool:Air Compressor]] | | | ||
+ | | [[tool:Ace A-27 2HP Dust Extractor]] | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | ====== Maintenance/ | ||
+ | ^ Machines ^ Supplies ^ | ||
+ | | [[hacks: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tools: | ||
====== Retirement ====== | ====== Retirement ====== |
tool.1554667576.txt.gz · Last modified: 2019/04/07 20:06 by jarrett
