Last revisionBoth sides next revision
tool [2019/04/05 22:23] 00739tool [2024/03/06 06:16] phillip_ma
 ====== Equipment and tools at VHS: ====== ====== Equipment and tools at VHS: ======
Line 17: Line 16:
-====== 3D Printing ======+====== 3D Printing Area ======
-See: [[area:3d-printing|3D Printing Work Area]]+See: [[area:3d-printing (Filament)|3D Printing Work Area]]
 ^ 3D printers  ^ Supplies  ^ Regular Printers ^ ^ 3D printers  ^ Supplies  ^ Regular Printers ^
-| [[tool:DittoPro|Tinkerine Ditto Pro]] | 3D Printing PLA Filament | [[tool:HP LaserJet 3600N]] | +| [[tool:DittoPro|Tinkerine Ditto Pro]] | [[tool:3d_filament|3D Printing Filaments]] | [[tool:HP LaserJet Pro 400]] |
-| [[tool:Prusai3|Prusa i3]] | 3D printing Resin |  +| [[tool:Prusai3|Prusa i3 with case]] | [[tool:3d_printing_resin|3D Printing Resin]] | [[tool:HP LaserJet 3600N]] |
-| [[tool:Form1SLA|Form 1]] | [[tool:glue|Glues]] | +| [[tool:Prusai3B|Prusa i3 without case]] | [[tool:nozzles|Nozzles and Parts]] |
 +| [[tool:Form1SLA|Form 1]] | [[tool:glue|Glues]]
 +| [[tool:ADIMLabsGantry|ADIMLabs Gantry]] |  |
 +| [[tool:Anycubici3mega|AnyCubic i3 Mega (for 3mm filament)]] |  |
 +| [[tool:Vaquform DT2|Vaquform DT2 Vaccuformer]] | |
-===== Casting =====+^ Loaner 3D printers ^ Model ^
 +| [[tool:loaners:3d-printers:Tevo|Tevo]] | Tevo Tarantula |
 +| [[tool:loaners:3d-printers:Franken-Printer | Franken Printer]] | Prusa i3 Clone |
 +| [[tool:loaners:3d-printers:Bob the (3D) Printer | Bob the (3D) Printer]] | Prusa i3 Clone |
-^ Tools               Modeling     ^  +^ SLA Printers (Resin) ^ Model ^
-| [[tool:pressure_chamber|Pressure Chamber]] | SolidWorks |  +| [[tool:3d-printers:AnyCubic Photon Mono]] | Photon Mono (small)|Photon Mono (small)|
-| [[tool:vacuum_chamber|Vacuum Chamber]] |  +| [[tool:3d-printers:AnyCubic Photon Mono X | Mono X (medium)]] | Mono X (medium) |
 +| [[tool:3d-printers:AnyCubic Photon M3 Max | M3 Max (Large)]] | M3 Max (Large) |
 +====== Paint & Mess Room ======
 +^ Tools               Software     ^
 +| [[tool:pressure_chamber|Pressure Chamber]] | [[tutorials:vhs_solidworks|SolidWorks]] |
 +| [[tool:vacuum_chamber|Vacuum Chamber]] | [[tutorials:fusion360|Fusion 360]]
 | [[tool:acrylic_bender|Acrylic Bender]] |  |  | [[tool:acrylic_bender|Acrylic Bender]] |  |
-| [[tool:injection_molder|Injection Molder]] |  | +| [[tool:vacuum_investment_casting_machine|Vacuum Investment Casting Machine]] |  |
-====== Crafting ======+====== Arts and Crafts ======
-See: [[area:crafting|Crafting Area]]+See: [[area:crafting|Arts and Crafts Area]]
 +===== Sewing =====
 ^ Machines ^ Tools ^ Supplies  ^ Misc ^ ^ Machines ^ Tools ^ Supplies  ^ Misc ^
-| [[tool:Sewing Machines]] | [[tool:Cutting Table]] | Pattern Paper | Mini Library | +| [[tool:Sewing Machines]] | [[tool:Cutting Table]] | [[tool:pattern_paper|Pattern Paper Roll]] | Mini Library |
-| [[tool:sewing_machines#VHS_sergers|Overlock sergers]] | [[tool:Badge a Minit Button Maker|Button Maker]] | Donated Fabric| Peg Board | +| [[tool:sewing_machines#VHS_sergers|Overlock sergers]] | [[tool:Silkscreening]] | Donated Fabric| Peg Board |
-| [[tool:ironing|Irons + Ironing Boards]] | [[tool:Silkscreening]] | Thermoplastic / Worbla | +| [[tool:ironing|Irons + Ironing Boards]] | [[tool:ironing#Dress_Form|Dress Form]] | Thermoplastic / Worbla | Pattern Weights
-| [[tool:ironing#Conair_Steamer|Conair Steamer]] | [[tool:ironing#Dress_Form|Dress Form]] | Thread Rack +| [[tool:ironing#Conair_Steamer|Conair Steamer]] |  | Notions | Thread Rack |
-| [[tool:vinyl_cutter|Vinyl Cutter]] |+| [[tool:relsew4000sw|Industrial Walking Foot]] |  | |
 +===== Art =====
 +^ Machine ^ Tools ^ Supplies ^ ^ ^
 +| [[tool:vinyl_cutter|Vinyl Cutter]] | Sculpting Tools | Origami paper | Stamps | Sidewalk chalk |
 +| [[tool:Badge a Minit Button Maker|Button Maker]] | Wood Burning Kit | Jewelry supplies and beads | Stamp ink | Markers |
 +|  | Paint and sponge brushes | Paint (watercolour, acrylic) | Balsa wood | Pencil crayons / pastels |
 +|  | Exacto Knife kit | Ribbons and string | pom-poms | leather scraps
Line 51: Line 76:
 ====== Electronics ====== ====== Electronics ======
-See: [[area:crafting|Crafting Area]] +See: [[area:electronics|Electronics Area]]
-^ Soldering Equipment  ^ Electronic Test Equipment  ^ Computer Equipment   ^ tools ^ Supplies ^ +
-| [[tool:Soldering Stations]] | [[tool:Digital Multimeters (DMMs)]] |  | [[tool:Terminal Crimper]] and ring terminals | [[tool:Solder]]   +
-| [[tool:Inspection Microscope]] | [[tool:Oscilloscopes]] |  | | [[tool:Solder Wick]]  +
-| [[tool:Hot Air Station]] | [[tool:Power Supplies]] |  | +
-| [[tool:Third Hands]] | [[tool:Logic Analyzer]] |  | +
-| [[tool:Panavise Junior]] | [[tool:Variac]] | [[tool:fpga-cluster|FPGA Cluster]] | +
-| [[tool:SMD Reflow Oven]] | [[tool:Function Generator]] |  | +
-|  | [[tool:Rigol MSO1074Z]] |  |+
 +^ Soldering Equipment  ^ Electronic Test Equipment  ^ Misc Equipment   ^ tools ^ Supplies ^
 +| [[tool:Soldering Stations]] | [[tool:Digital Multimeters (DMMs)]] | [[tool:oscillator_model_k8202_400v_ac_power_supply| 400v power supply]] | [[tool:Terminal Crimper]] and ring terminals | [[tool:Solder]] |
 +| [[tool:Inspection Microscope]] | [[tool:Oscilloscopes]] | [[tool:voltbox_ac_power_supply| Voltbox AC Power Supply]] | [[tool:Battery Spot Welder]] | [[tool:Solder Wick]] |
 +| [[tool:Hot Air Station]] | [[tool:Power Supplies]] | [[tool:powerbright_vc-750w_step_up_down_transformer| Powerbright vc-750w transformer]] |  |Flux |
 +| [[tool:Third Hands]] | [[tool:Logic Analyzer]] |  |  | Copper tip cleaner |
 +| [[tool:Panavise Junior]] | [[tool:Variac]] |  |  | Tweezers |
 +| [[tool:SMD Reflow Oven]] | [[tool:Function Generator]] |  |  | Cleaning Brushes |
 +| [[tool:Infrared IC Heater]] | [[tool:Rigol MSO1074Z]] |  |
 +| [[tool:Hakko Omnivise PCB Holder]] |  |  |
 +| [[tool:Essemtec PCB Oven]] | | |
 +| [[tool:Essemtec Pick and Place]] | | |
 +|.[[tool:Essemtec Stencil Screen Printer]] | | |
 ====== The Hangout ====== ====== The Hangout ======
-See: [[area:the_hangout|The Hangout]], [[area:server_room|Server Room]], [[area:Leopard_room|Leopard Room]]+See: [[area:the_hangout|The Hangout]], [[area:ops_room|Ops Room]], [[area:Leopard_room|Leopard Room]], [[Area:washrooms|Washrooms]]
 ^ Machines ^ Supplies ^ misc ^ ^ Machines ^ Supplies ^ misc ^
-| [[tool:Industrial Arm]] | Office supplies | Admin Cabinet | +| [[tool:Industrial Arm]] | [[tool:officesupply|Office supplies]] | [[tool:admincabinet|Admin Cabinet]]
-| [[tool:Mini-fridge]] | Labelling supplies [[tool:Brother QL-570 Label Printer]] | Arcade Machine| +| [[tool:Mini-fridge]] | [[tool:Keggerator]] | [[tool:labelingsupplies|Brother QL-570 Label Printer]] | [[tool:arcademachine|Arcade Machine]]
-| [[tool:Chromecast|Chromecast TV and Speakers]] | Cleaning supplies |+| [[tool:Chromecast|Chromecast TV and Speakers]] | [[tool:labelingsupplies#box of label strips|Labeling supplies]] | [[hacks:led_wall|LED Wall]] |
 +| [[tool:ultrasonic_cleaner|Ultrasonic Cleaner]] | [[tool:cleaning_supplies|Cleaning supplies]] [[tool:social_buttons|VHS Social Buttons]] |
 +| [[tool:Microwave]] |
 +| [[tool:Video Wall]] |
 +===== Ops Room =====
 +See: [[area:ops_room|Ops Room]]
 +^ Servers ^
 | [[tool:server_rack|Server Rack]] | | [[tool:server_rack|Server Rack]] |
 +| [[infrastructure:servers#space|Infrastructure Servers]] |
 +| [[tool:fpga-cluster|FPGA Cluster]] |
Line 82: Line 120:
 ^ Machines ^ Supplies ^  ^ Machines ^ Supplies ^
 | [[tool:refrigerator]] | Beer? |  | [[tool:refrigerator]] | Beer? |
-| [[tool:coffee_machine]] | Cups | +| [[tool:coffee_machine|Coffee Machine]] | Cups |
-| [[tool:hot plate]] | +| [[tool:hot plate]] | [[tool:Brewing Equipment]] |
 +| [[tool:Convection Oven]] |
Line 92: Line 131:
-| [[tool:RedSail CM1080 Laser Cutter]] | Laser cutter material storage |  +| [[tool:RedSail CM1080 Laser Cutter]] | [[area:material_storage|Laser cutter material storage]] |
-| Laser cutter filtration system |  |+| [[tool:laserfilter|Laser cutter filtration system]] [[tool:laser_cutter:settings|Approved Laser Cutter Materials]] |
-====== Metal Work ======+====== CNC Area======
-See: [[area:metal_shop|Metal Shop]], [[area:welding_zone|Welding Zone]]+See: [[area:metal_shop|Machine Shop]]
-^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^ misc +^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^
-| [[tool:Sherline CNC Mill]] | [[tool:Welder]] | Hand Tools | Safety Equipment | Donated metal +| [[tool:Sherline CNC Mill|Sherline]] | Shopvac (Shared with Machine Shop) | Hand Tools | Safety Equipment |
-| [[tool:Grizzly X3 4-Axis CNC Mill]] [[tool:Norseman Drill Bit Set]] | | Flux | +| [[tool:Grizzly X3 4-Axis CNC Mill|CNC Mill "Gage"]] |  | CNC Tool Library (WIP) | Flux |
-[[tool:manual_lathe|Metal Lathe]] | [[tool:18.0V Cordless Drill]] | | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] | +CNC Mill "Jaxon"   | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]]
-| [[tool:Drill Press]] [[tool:Bosch 4.5Angle Grinder]] | +| [[tool:6040 CNC Mill|6040 CNC Mill "Laratron"]] |
-| [[tool:Green Manual Mill]] | [[tool:Cut-Off Saw]] | +| [[tool:Drill Press]] |
-| [[tool:Bench Bandsaw]] | +
-| [[tool:Horizontal Bandsaws]] | +
-| [[tool:Bench Grinder]] | +
-| [[tool:Scroll Saw]] | +
-| [[tool:Buffing Machine]] |+
-====== Woodworking ======+====== Machine Shop ======
-See: [[area:Woodworking|Woodwork Area]]+See: [[area:metal_shop|Machine Shop]]
-| [[tool:Wood CNC]] | [[tool:Thickness Sander]] | hammer glues | [[hacks:woodshop_automatic_dust_extraction_system_wades|Woodshop Automatic Dust Extraction System (WADES)]] +| [[tool:Green Manual Mill]] | [[tool:Welder|Millermatic 211 MIG Welder]] | Hand Tools Safety Equipment |
-| [[tool:Drill Press]] | [[tool:Norseman Drill Bit Set]] | [[tool:wood steamer|Wood Steamer]] | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] | +| [[tool:manual_lathe|Metal Lathe]] | [[tool:PowerTIG250EX|PowerTIG 250EX Welder]] | [[tool:Norseman Drill Bit Set]] | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] |
-| [[tool:Bench Bandsaw]] | [[tool:Random-Orbit Palm Sander]] | [[tool:glue|Glues]] +| [[tool:Bench Bandsaw]] | |
-| [[tool:Scroll Saw]] | [[tool:18.0V Cordless Drill]] | +| [[tool:Horizontal Bandsaws]] | |
-| [[tool:Table Saw]] | [[tool:Jointer]] | +
-| [[tool:Mini Wood (Pen) Lathe]] | [[tool:Cut-Off Saw]] | +
-| [[tool:Small Wood Lathe]] | [[tool:Planer 40200H]] |+
 +====== Metal Shop ======
 +See: [[area:welding|Metal Shop]]
-===== The Consumables =====+^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^
 +| Box and Pan Brake | [[tool:Welder|Millermatic 211 MIG Welder]] | Hand Tools | Safety Equipment |
 +| Welding Table | [[tool:PowerTIG250EX|PowerTIG 250EX Welder]] | | Flux |
 +| [[tool:manual_lathe|Metal Lathe]] | [[tool:Bosch 4.5" Angle Grinder]] | | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] |
 +| [[tool:Bench Grinder]] | [[tool:Cut-Off Saw]] |  | Donated metal |
 +| [[tool:Green Manual Mill]] | [[tool:18.0V Cordless Drill]] |
 +| [[tool:Bench Bandsaw]] | [[tool:Plasma Cutter]] |
 +| [[tool:Horizontal Bandsaws]] | [[tool:Ring Roller]] |
 +| [[tool:Scroll Saw]] |
 +| [[tool:Buffing Machine]] |
 +| [[tool:Blacksmith forge and anvil]] |
 +| [[tool:Heat Treating Oven]] |
-^ Soldering               ^ Semiconductors         ^ Hardware       ^ Plastics ^ +-----
-===== VHS Chemical Storage =====+====== Woodworking ======
-[[chemical-storage|VHS Chemical Storage Policy]]+See: [[area:Wood_shop|Wood Shop]]
 +| [[tool:Wood CNC]] | [[tool:Thickness Sander]] | hand tools | [[tool:glue|Glues]] |
 +| [[tool:Drill Press]] | [[tool:Random-Orbit Palm Sander]] | [[tool:wood steamer|Wood Steamer]] | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] |
 +| [[tool:Bench Bandsaw]] | [[tool:18.0V Cordless Drill]] | [[tool:Norseman Drill Bit Set]] |  |
 +| [[tool:Scroll Saw]] | [[tool:Jointer]] | [[tool:French Cleat Wall]] |  |
 +| [[tool:Table Saw]] | [[tool:Cut-Off Saw]] |
 +| [[tool:Mini Wood (Pen) Lathe]] | [[tool:Planer 40200H]] |
 +| [[tool:Small Wood Lathe]] | [[tool:7-1/4-inch Circular Saw]] |
 +| [[tool:Barry the 14" Bandsaw]] |  |
 +| [[tool:Bernie the Spindle Sander]] |  |
 +| [[tool:Bosch Miter Saw]] |  |
 +| [[tool:Hammer Jointer/Planer]] |  |
 +| [[tool:Air Compressor]] |  |
 +| [[tool:Ace A-27 2HP Dust Extractor]] | [[tool:Delta Dust Extractor]]  |
 +| [[tool:Ridgid 16 Gallon Shop Vacuum]] | [[tool:Ridgid 4 Gallon Portable Vacuum]] |
 +| [[tool:Magnum Industrial Dust Collector]] |[[tool:Dremel Vibrating Multi Tool]]  |
 +====== Maintenance/Facility ======
 +^ Machines ^ Supplies ^
 +| [[hacks:wades|Woodshop Automatic Dust Extraction System (WADES)]] | machine oil |
 +| [[tool:powertec_air_filter|POWERTEC AF1044 3SPD Air Filtration System]] |
 +| [[tool:transformer|20kVA Transformer]] |
 +| [[tools:Boge Air Compressor|Boge Air Compressor]] |
-===== Other ===== +====== Retirement ======
-  * [[tool:ultrasonic_cleaner|Ultrasonic Cleaner]] +
-  * [[tool:powertec_air_filter|POWERTEC AF1044 3SPD Air Filtration System]]+
-===== Candidates for Retirement ===== +[[area:Retirement|Candidates for Retirement]] \\
-  * [[area:Retirement]] +[[area:Retired Equipment]]
-  [[tool:pcb_mill]]+
-===== Retired Equipment =====
-  * [[area:Retired Equipment]]
-  * [[tool:Portable Table Saw]]
-  * [[area:3d-printing#PrintrbotLC|Printrbot LC]]
-  * [[area:3d-printing#Tantillus|Tantillus]]
-  * [[tool:Z-Corporation Z402 3D printer]]
-  * [[tool:district9_blades|District 9 Blades]]
-  * [[tool:Kiln]]
-  * [[tool:Barbeque|Barbeque]] (In storage)
-  * [[tool:Taig CNC Mill]]
-  * [[tool:vending_machine|Vending Machine]]
tool.txt · Last modified: 2024/04/29 05:27 by dbynoe
