hacks:wades
hacks:woodshop_automatic_dust_extraction_system_wades [2019/04/05 05:21] – ↷ Page moved from tool:woodshop_automatic_dust_extraction_system_wades to hacks:woodshop_automatic_dust_extraction_system_wades jarrett | hacks:wades [2019/04/18 01:32] (current) – 00739 | ||
+ | ====== Woodshop Automatic Dust Extraction System (WADES) ====== | ||
In January 2019 JohnC sought out to build a Woodshop Dust Extraction Automation System (WADES) simliar to the one he built for the Science World exhibits fabrication workshop in 2018. The system uses a Programmable Logic Controller (PLC) control panel connected via long wires to current sensors mounted at each tool. | In January 2019 JohnC sought out to build a Woodshop Dust Extraction Automation System (WADES) simliar to the one he built for the Science World exhibits fabrication workshop in 2018. The system uses a Programmable Logic Controller (PLC) control panel connected via long wires to current sensors mounted at each tool. | ||
hacks/wades.txt · Last modified: 2019/04/18 01:32 by 00739
