hacks:openrov_build
no way to compare when less than two revisions
Previous revision | |||
— | hacks:openrov_build [2015/12/12 14:31] (current) – external edit 127.0.0.1 | ||
+ | ====== OpenROV Build ====== | ||
+ | A few people have expressed interest in building an [[http:// | ||
+ | **Next Steps** | ||
+ | * Determine what version to build. | ||
+ | * Put together a BOM using as many local sources as possible. | ||
+ | * Start gathering the parts. | ||
+ | * Continue to examine the BBB software. | ||
+ | **Initial Look** | ||
+ | At this stage, it's been mostly research. | ||
+ | The point of all this was basically to get familiar with the BBB, and get a bit of insight into the project. | ||
+ | * I have not purchased the OpenROV Cape (the BBB version of a shield for any Arduino folks out there). | ||
+ | * I've joined the OpenROV site. I sent in a request from the login screen, and within the day I was added. | ||
+ | * I also joined the Google+ OpenROV group. | ||
+ | * I've downloaded the DXF files for the plastic parts. | ||
+ | * OpenROV requests that you etch a serial number in to each build. | ||
+ | Total Cost to Date: **$65 cdn** |
hacks/openrov_build.txt · Last modified: 2015/12/12 14:31 by 127.0.0.1
