hacks:led_wall
hacks:led_wall [2019/04/07 16:58] 00739hacks:led_wall [2019/04/07 16:59] (current) 00739
Line 27: Line 27:
 The teensy could be paired with the pi to stream animations sequenced in a looping queue.  Then people could create new animations and dynamically adjust the queue without affecting the teensy.  this would be easier than reprogramming the teensy over and over.  what format the queue and the animations take is unknown at this time. The teensy could be paired with the pi to stream animations sequenced in a looping queue.  Then people could create new animations and dynamically adjust the queue without affecting the teensy.  this would be easier than reprogramming the teensy over and over.  what format the queue and the animations take is unknown at this time.
-== LED Wall 2014? ==+==== LED Wall 2014? ====
 [[https://github.com/TyIsI/VHSled|VHSled]] on Ty's Github was the most recent. The [[https://www.facebook.com/photo.php?v=10152238520907526|LED wall]] was run off a Raspberry Pi under the wall.  [[https://github.com/TyIsI/VHSled|VHSled]] on Ty's Github was the most recent. The [[https://www.facebook.com/photo.php?v=10152238520907526|LED wall]] was run off a Raspberry Pi under the wall.
hacks/led_wall.txt · Last modified: 2019/04/07 16:59 by 00739
