hacks:filament_extruder
no way to compare when less than two revisions
Previous revision | |||
— | hacks:filament_extruder [2015/12/12 14:31] (current) – external edit 127.0.0.1 | ||
+ | ====== About ====== | ||
+ | VHS members & fans plan to build a [[http:// | ||
+ | This project requests your assistance. | ||
+ | Example: | ||
+ | * //Dan R// Doing a thing | ||
+ | Together we can make this happen! | ||
+ | ====== The Plan ====== | ||
+ | * Acquire all the parts | ||
+ | * Assemble the device | ||
+ | * Test the device | ||
+ | * Teach other how to use & maintain it | ||
+ | * Upgrade the device | ||
+ | ===== Acquire all the parts ===== | ||
+ | * //needs a sponsor// Digitize the part list into a Google Doc so we can track the status of every part. | ||
+ | * //Dan R// A bin must be created to hold all the parts. | ||
+ | * Once the list is digital we can divide the work of acquiring parts. | ||
+ | * We may even be able to get a grant from VHS to fund the project. | ||
+ | * Once we have every part we can begin Assembly | ||
+ | ===== Test the device ===== | ||
+ | ===== Teach other how to use & maintain it ===== | ||
+ | ===== Upgrade the device ===== | ||
+ | * Put the device into a quick-access storage system so that it doesn' | ||
+ | ====== See Also ====== | ||
+ | * [[Projects]] |
hacks/filament_extruder.txt · Last modified: 2015/12/12 14:31 by 127.0.0.1
