hacks:face_casting
no way to compare when less than two revisions
Previous revision | |||
— | hacks:face_casting [2015/12/12 14:31] (current) – external edit 127.0.0.1 | ||
+ | ==== Face casting ==== | ||
+ | Contact: Alan Bucior | ||
+ | You can get an idea of the overall process [[http:// | ||
+ | ==== Best practices ==== | ||
+ | == Step 1: Prep == | ||
+ | * Make sure you have a lot of space and nearby access to warm water and a garbage can. | ||
+ | * Hair should ideally be covered by a swim cap. Hair that still shows should ideally be covered with some sort of release agent such as Vaseline, but short hair seems to pull away without much of a problem. | ||
+ | * The rest of the body should be covered with a plastic dropsheet or similar. | ||
+ | * Alginate will get on the floor. It's easy to clean up if it's a hard floor. Carpet would be a disaster. | ||
+ | * Pre-measure everything and have mixing bowls ready. | ||
+ | * Have warm water on hand. | ||
+ | * Have lots of paper towel handy. | ||
+ | * Pre-cut all your plaster/ | ||
+ | == Step 2: Alginate == | ||
+ | * We use Alji-Safe from Smooth-On. This is available in town from [[http:// | ||
+ | * We've tried Alji-Safe Acrobat, but found it too lumpy. It may be usable if you use a Jiffy Mixer to mix it smoothly. | ||
+ | * Alginate is mixed 1:1 with warm water by volume. | ||
+ | * One face requires about 2-2.5 plastic disposable cups worth of alginate. | ||
+ | * It sets up quite quickly (~5 min), and I think it sets up quicker the warmer the water. One person can do it if they move fast. Ideally two people so that one can concentrate on detail bits like the nose while the other concentrates on the edge areas like the chin and forehead. | ||
+ | * Apply a thin coat of alginate to the face first. Bubbles often form in the eye sockets where it meets the nose. Assume there' | ||
+ | == Step 3: Plaster & Bandages == | ||
+ | * Pre-plastered bandages were bought from an art store. (Opus has them, or Fibertek) | ||
+ | * They just need to be dipped in warm water and applied. | ||
+ | * Mostly larger strips work better but a few small strips are needed for around the nose. | ||
+ | * Ideally two layers of bandages for coverage. | ||
+ | * This whole step is easy and fairly error-proof. | ||
+ | == Step 4: Casting == | ||
+ | * Plug the nose holes! | ||
+ | * Our casting medium of choice is [[http:// | ||
+ | * The mix ratio is 32:100 water: | ||
+ | * Water should be at 27 degrees C, or just a bit warm to the hand. | ||
+ | * About 5 plastic cups is appropriate for a full face cast. | ||
+ | * Hydrostone' | ||
+ | * Goes hard in 15 minutes. Can demold in about 35 minutes! | ||
+ | ==== Post-mortems ==== | ||
+ | === Face cast 1 === | ||
+ | Caster: Alan Bucior | ||
+ | Castee: Steven McCullough | ||
+ | == Amounts == | ||
+ | * Alji-safe: 2 cups and 2 cups water. Perhaps could use a bit more | ||
+ | * Ultracal: 2.5 cups, with 1 cup water. Definitely need more for a deeper cast, and probably a bit less water. Probably something like 3.5 cups to 1 cups water. | ||
+ | == Issues == | ||
+ | * Not deep enough | ||
+ | * Next time we'll try to get more depth by casting more of the face and forehead. | ||
+ | * Nose detail poor | ||
+ | * Next time I think we should try using straws in the nose to be able to cover more of the skin of the nose. Also, breathing out seemed to push away the alginate and bandages. By pushing the air through straws we may be able to mitigate that. | ||
+ | === Face cast 2 === | ||
+ | Casters: Steven McCullough, Rob Butterworth | ||
+ | Castee: Alan Bucior | ||
+ | * Alji-safe: 3 cups and 3 cups water. Way too much. 2.5 cups next time? Or maybe just 2 is good enough. | ||
+ | * Ultracal: We didn't measure it and just eyeballed it, which was fine (EDIT: No, it was not fine. Mix accurately next time). Mixed for consistency. | ||
+ | == Results == | ||
+ | * We concentrated on getting good depth and we used a swimming cap. We got great depth and decided to do the ears, but the ears were totally unnecessary and rose way above the usable depth. Next time concentrate on getting more of the forehead and less of the ears. | ||
+ | * We used straws in the nose and that worked fairly well. Though it left two small very round holes. I think rolled paper might work better as it'll better conform to the shape of the nose. | ||
+ | * A few bubbles on the face, but those can be fixed up. | ||
+ | * I'm concerned that the Ultracal isn't giving enough fine detail. It should be performing better, but it seems like a thin outer layer sloughs off when you demold. Perhaps we should try plaster next time. I've also heard good things about Hydrostone, so maybe we should try that. | ||
+ | === Face cast 3 === | ||
+ | Casters: Alan Bucior, Steven McCullough | ||
+ | Castee: Rob Butterworth | ||
+ | * Alji-safe Acrobat: 2.5 cups. About right. Could even do just 2 cups. Seemed too lumpy. Needs mechanical mixing. | ||
+ | * Hydrostone: 4 cups, measured water very accurately. Was a good amount, but could have gone even deeper. 6 cups would get lots more depth. | ||
+ | * We used a swimming cap, and marked a straight line on the head with tape to make we didn't go too high in parts and too low in others. We didn't do the ears. | ||
+ | * We used paper tubes in the nose and that worked fairly well. But when we cast the head we forgot to plug the nose resulting in plaster protrusions. | ||
+ | * A few bubbles on the face in the eye socket area where it meets the nose. Next time try scooping that area. Also try wetting the face first. | ||
+ | * Hydrostone worked awesomely. | ||
+ | * I checked the docs a bit more. Smooth-on recommends using a Jiffy Mixer or Turbine Mixer attachment on a drill to get a smooth product with Acrobat. I’ll pick one up this weekend. I think ICI Paints has them. | ||
+ | * We should make sure in the future to apply a light coat to the eyes and scoop out any air bubbles before adding more. | ||
+ | * Interestingly, | ||
+ | * I’ve noticed that every time, our plaster gauze cast goes from very hard to very soft as it gets further wetted from the alginate. We might try a few things: | ||
+ | * More plaster gauze. At LEAST 2 layers. Maybe 3 | ||
+ | * Maybe try a different brand. I think Fibertek has some medical grade stuff. We can try that. | ||
+ | * Maybe we put a layer of plastic wrap between the alginate and the cast after de-mold. | ||
+ | === Face cast 4 === | ||
+ | Casters: Alan Bucior, Steven McCullough, Rob Butterworth | ||
+ | Castee: Andrew Milne | ||
+ | * Alji-safe Acrobat: 2.5 cups. Perfect. | ||
+ | * Hydrostone: 5 cups (2750g), measured appropriate water very accurately. Perfect. | ||
+ | * Near perfection. Perfect detail. Only a few air bubbles in the chin area, where facial hair stubble probably trapped some air. Next time make sure to smooth down stubbly areas. | ||
+ | * Smoothing out the eyes worked perfectly. | ||
+ | * Seems like an initial thinner layer of alginate over the face works well to reduce slumping, remove bubbles, and preserve detail. | ||
+ | * Nose holes plugged with alginate. Worked well. | ||
+ | * Hydrostone one again worked awesomely. | ||
+ | * Still issues with plaster gauze not going 100% hard. Need to research whether gypsona would work better. |
hacks/face_casting.txt · Last modified: 2015/12/12 14:31 by 127.0.0.1
