hacks:boards:rtos:zephyr:cmake
Zephyr Project @ VHS
The following instructions are for building the latest version of Zephyr, which uses CMake for configuring the build instead of Automake.
Build the latest version of CMake
git clone https://gitlab.kitware.com/cmake/cmake.git cd cmake/ git tag -l git checkout v3.8.2
./bootstrap && make -j8 sudo make install
type -a cmake dpkg -S /usr/bin/cmake gvim -p ~/.bashrc ~/.profile
alias cmake='/usr/local/bin/cmake'
wget https://github.com/zephyrproject-rtos/meta-zephyr-sdk/releases/download/0.9.2/zephyr-sdk-0.9.2-setup.run
sudo bash zephyr-sdk-0.9.2-setup.run
Download the Latest Zephyr Code
git clone <zephyr yada yada yada
#Check Repository name git remote -V
# git pull –rebase zephyr master
http://docs.zephyrproject.org/getting_started/getting_started.html
export ZEPHYR_GCC_VARIANT=zephyr export ZEPHYR_SDK_INSTALL_DIR=/opt/zephyr-sdk/
cd zephyr source ./zephyr-env.sh
cd $ZEPHYR_BASE/samples/hello_world
# Make a build directory, and use cmake to configure a Make-based build system: mkdir -p build/disco_l457_iot1 && cd build/disco_l457_iot1 cmake -DBOARD=disco_l475_iot1 ../..
# Now run make on the generated build system: make -j8
cd src/openocd-stm32 source ./setlocal.sh
cat setlocal.sh
stm32_flsh l4 $ZEPHYR_SOURCE/samples/hello_world/build/disco_l475_iot1/zephyr/zephyr.bin
ls -al /dev/ttyACM0 minicom -D /dev/ttyACM0
press reset
hacks/boards/rtos/zephyr/cmake.txt · Last modified: 2017/11/24 06:58 by jdmc
