admin:code_of_conduct
Both sides previous revisionPrevious revision | Last revisionBoth sides next revision | ||
admin:code_of_conduct [2019/05/27 00:54] – dbynoe | admin:code_of_conduct [2020/07/17 00:31] – Removed an empty trailing list item in the "Grievance Procedure>Introduction" list paroxon | ||
Line 56: | Line 56: | ||
- Before the formal banning procedure is entered into, the BoD must make every attempt to resolve the issue informally. | - Before the formal banning procedure is entered into, the BoD must make every attempt to resolve the issue informally. | ||
- However, in the case of direct physical violence towards any person in the space, a member has the authority to immediately ban the offender for one month and refer the case to the BoD. | - However, in the case of direct physical violence towards any person in the space, a member has the authority to immediately ban the offender for one month and refer the case to the BoD. | ||
=== Process === | === Process === | ||
- The BoD investigates complaints and determines the validity of the complaint and determines whether the described behaviour is in violation of VHS rules or Code of Conduct. | - The BoD investigates complaints and determines the validity of the complaint and determines whether the described behaviour is in violation of VHS rules or Code of Conduct. |
admin/code_of_conduct.txt · Last modified: 2022/03/27 04:40 by evn
