#FPGA environment
export QSYS_ROOTDIR="/home/tdwebste/intelFPGA_lite/16.1/quartus/sopc_builder/bin"
source ~/.setup_epiphany_rc
source ~/setenv.sh
export XILINX_VER=2016.4
#export XILINX_VER=2015.1
#export XILINX_VER=2014.3.1
source /opt/Xilinx/Vivado/${XILINX_VER}/settings64.sh
export PATH=$PATH:/opt/Xilinx/Vivado/${XILINX_VER}/bin
#!/bin/sh -f
# Copyright (c) 2010, All Right Reserved, Adapteva, Inc.
# This source is subject to the Adapteva Software License.
# You should have received a copy of the full license file
# named ("LICENSE") along with this program. If not, contact
# Adapteva immediately at support@adapteva.com
case $(uname -m) in
x86_64)
_esdk_arch=".x86_64"
arm*)
_esdk_arch=".armv7l"
_esdk_arch=""
esac
export EPIPHANY_HOME=/opt/adapteva/esdk
if [ -z "$EPIPHANY_HOME" ]; then
echo "Please set the EPIPHANY_HOME to the root folder of the SDK release!"
else
PATH=${EPIPHANY_HOME}/tools/a-gnu/bin:${PATH}
PATH=${EPIPHANY_HOME}/tools/e-gnu${_esdk_arch}/bin:${PATH}
PATH=${EPIPHANY_HOME}/tools/host${_esdk_arch}/bin:${PATH}
LD_LIBRARY_PATH=${EPIPHANY_HOME}/tools/host${_esdk_arch}/lib:${LD_LIBRARY_PATH}
LD_LIBRARY_PATH=${EPIPHANY_HOME}/tools/e-gnu${_esdk_arch}/lib:${LD_LIBRARY_PATH}
EPIPHANY_HDF=${EPIPHANY_HOME}/bsps/current/platform.hdf
MANPATH=${EPIPHANY_HOME}/tools/e-gnu/share/man:${MANPATH}
MANPATH=${EPIPHANY_HOME}/tools/e-gnu${_esdk_arch}/share/man:${MANPATH}
export PATH
export LD_LIBRARY_PATH
export EPIPHANY_HDF
export MANPATH
fi
unset _esdk_arch
Total lacks READMEs so you have no idea how to build this stuff.
cd sdk
bash download-components.sh - -clone
mkdir /opt/adapteva; cd /opt/adapteva
ln -s esdk.master esdk
source ./setup.sh
it may be necessary to install guile
bash build-toolchain.sh –clean –clean-host –clean-build
bash build-pal.sh
bash build-epiphany-libs.sh
It is not necessary and it is not possible to build-epiphany-sdk.sh Please use the prebuild sdk previously downloaded.
