====== Name of Tool ====== {{:tool:af1044_main_13777.1438489176.1280.1280.jpg?400|}} Summary description of the tool and perhaps some misc notes about it's existence! ^ Status | Operational as of Mar 12, 2019 | ^ Training | Optional | ^ Hackable | NO | ^ Usage Restrictions | Anyone | ^ Owner | VHS | ^ If it Breaks | (Panic procedure, usually involving emailing list and "broken" sign) | ^ Loan Status | Owned | ^ Arrival Date | April 2016 | ^ Location | Woodshop | ^ Value | $300 | ^ Champion | See [[tool:compendium_of_champions#tools|Compendium of Champions]] | ===== Safety ===== This should outline safety concerns and guidelines for the tool and it's operation. ===== Specifications ===== https://www.amazon.ca/gp/product/B012MI1G3W/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1 http://powertecproducts.com/af1044-3spd-air-filtration-system-556-702-1044-cfm/ {{ :tool:af1044manual.pdf |}} Horsepower (Maximum Developed): .1/5 HP, 120 V, 60 Hz 3 Speeds, Motor Amperage: 3A/ 2-1/2A / 2A; Motor Speeds: 750/960/1200 RPM, Air Flow: 556/702/1044-CFM, Outer Filter: 5 Micron, Inner Filter: 1 Micron, Filtration Timing: 1HR, 2HR, 4HR, Gross Weight: 73 lbs, Sound Rating @ 3 Feet: High Speed : 69dB, Medium Speed 67dB, Low Speed 62 dB . Powerful, quiet, efficient, and potent air filtration system . Easy to replace filter; no tools required; Outer filter: 5 micron; Inner filter: 1 micron . 3 Air flows: 556/702/1044-CFM . Infrared remote control system; 3 timer setting: 1hr/2hr/4hr . Includes remote control and mounting hardware Replacement filters: * POWERTEC 75019 INNER FILTER FOR POWERTEC AF1044 http://powertecproducts.com/powertec-75019-inner-filter-for-powertec-af1044/ * POWERTEC 75020 OUTER FILTER FOR POWERTEC AF1044 http://powertecproducts.com/powertec-75020-outer-filter-for-powertec-af1044/ ===== Tutorial ===== Instructions on how to use the tool or links to references, pdf guide or something. This should be a solid basis for any required training. http://powertecproducts.com/content/AF1044Manual.pdf ===== Maintenance Log ==== Any maintenance, repairs, relocations, changes, etc to the tool should be logged below with a note, date and who! ^ Note ^ Date ^ Who ^ | Wiki entry created | Mar 12, 2019 | Thomas L. |
