{{:tool:heat_treat_oven.jpg?300|}} ====== Information: ====== * **owner** = Vancouver Hack Space * **no certification required** = Tool certification doesn't exist yet. * **hackable** = No (See tips below) * **model** = Paragon KM 14T * **serial #** = * **arrived** = 2021 * **does it work?** = Works * **if it breaks** = Unplug machine, put a broken sign on machine, post on Talk. * **contact** = Machine Shop/Welding Shop * **where** = Machine shop * **value** = $$$$ [[https://paragonweb.com/home/5c212jmb00/#|This Link points to Paragon KM14T oven]] [[https://www.youtube.com/watch?v=trHHWl6ncr4|A video review of a similar Paragon oven]] ====== Safety at a Glance ====== __Hot:__ * If it wasn't obvious, ovens make things hot. This oven is extra spicy. Follow all safety procedures for really really hot things. * Know where you are going to put hot things and clear those areas and the paths between them before things are hot. * Do not leave the space while things (material, oven, tools, etc) are still hot. * Fire watch for 30 minutes after everything is cool. __Time:__ * Any operation with this oven takes time, plan accordingly. * Example Timing Info: "It took 55 minutes to get to 1550 including a 40 drop when I peeked to take a pic at about 1400.." __Buddy Up:__ * Consider working with a buddy to help with doors and hot things. * If working with a buddy is not viable, consider working when others are within earshot. {{:tool:img_thermal_1652049922585.jpg?direct&400|}} {{:tool:img_thermal_1652049897487.jpg?direct&400|}} {{:tool:img_thermal_1652049986140.jpg?direct&400|}} ===== Controls ===== The oven has a programmable controller. Manual attached here {{:tool:im204-sentry12key-cfrh-nov2018.pdf}}
