====== Grizzly G0463 Mill ====== ^ model | Grizzly G0463 (a Seig X3) | ^ Status | Operational | ^ Usage Restrictions | Members with Training | ^ Training | Mandatory | ^ User certification required | YES | ^ Hackable | NO | ^ Owner | Richard Sim | ^ If it Breaks | Let Richard know, put up an Out of Order sign | ^ Loan Status | Semi-Permanent Loan | ^ Arrival Date | November 12th 2012 | ^ Location | Workshop | ^ Champion | Richard Sim | ===== Safety ===== If you don't know what you are doing don't touch it. ===== Specifications ===== This is a custom CNC conversion from a Grizzly G0463 manual milling machine. It has a lot of expensive upgrades and tooling, including a 4th (rotary) axis. It has a 2.5HP motor which runs up to ~5500 RPM and as such is capable of cutting most materials, even hardened steel with the appropriate tooling. Each axis is driven by very heavy duty industrial drivers (each is almost the size of an entire 3D printer) and runs on ball screws for almost zero backlash. ===== Training ===== Mandatory training specific to this machine is required. Users must first be trained on the [[retirement:taig_cnc_mill|Taig CNC mill]], and be able to demonstrate competency in its use. ===== Speeds & Feeds ===== Use the cutting speed calculator on the CNC PC to calculate appropriate cutting speeds for your material, cutting tool, and depth of cut combination. It is very important to have the correct feed rates for a cut in addition to the correct RPM on CNC machines. ===== Maintenance Log ===== Any maintenance, repairs, relocations, changes, etc to the tool should be logged below with a note, date and who! ^ Note ^ Date ^ Who ^ | Moved to new workshop location and re-setup | January 14, 2017 | Luke B | | Wiki entry updated | Aug 8, 2014 | Richard Sim | | Ballscrew repair in-progress | Aug 3, 2014 | Richard Sim |
