tool [2022/02/21 19:25] robtool [2024/10/27 15:48] (current) johnc
 ====== Equipment and tools at VHS: ====== ====== Equipment and tools at VHS: ======
Line 19: Line 18:
 ====== 3D Printing Area ====== ====== 3D Printing Area ======
-See: [[area:3d-printing|3D Printing Work Area]]+See: [[area:3d-printing (Filament)|3D Printing Work Area]]
 ^ 3D printers  ^ Supplies  ^ Regular Printers ^ ^ 3D printers  ^ Supplies  ^ Regular Printers ^
-| [[tool:DittoPro|Tinkerine Ditto Pro]] | [[tool:3d_filament|3D Printing Filaments]] | [[tool:HP LaserJet Pro 400]] |+| [[tool:voron_v2.4_voltron|Voron v2.4 350mm: Voltron]] | [[tool:3d_filament|3D Printing Filaments]] | [[tool:HP LaserJet Pro 400]] |
 | [[tool:Prusai3|Prusa i3 with case]] | [[tool:3d_printing_resin|3D Printing Resin]] | [[tool:HP LaserJet 3600N]] | | [[tool:Prusai3|Prusa i3 with case]] | [[tool:3d_printing_resin|3D Printing Resin]] | [[tool:HP LaserJet 3600N]] |
-| [[tool:Prusai3B|Prusa i3 without case]] | [[tool:nozzles|Nozzles and Parts]] | +| [[tool:DittoPro|Tinkerine Ditto Pro]] | [[tool:nozzles|Nozzles and Parts]] |
 | [[tool:Form1SLA|Form 1]] | [[tool:glue|Glues]] | | [[tool:Form1SLA|Form 1]] | [[tool:glue|Glues]] |
 | [[tool:ADIMLabsGantry|ADIMLabs Gantry]] |  | | [[tool:ADIMLabsGantry|ADIMLabs Gantry]] |  |
Line 34: Line 33:
 | [[tool:loaners:3d-printers:Franken-Printer | Franken Printer]] | Prusa i3 Clone | | [[tool:loaners:3d-printers:Franken-Printer | Franken Printer]] | Prusa i3 Clone |
 | [[tool:loaners:3d-printers:Bob the (3D) Printer | Bob the (3D) Printer]] | Prusa i3 Clone | | [[tool:loaners:3d-printers:Bob the (3D) Printer | Bob the (3D) Printer]] | Prusa i3 Clone |
 +^ SLA Printers (Resin) ^ Model ^
 +| [[tool:3d-printers:AnyCubic Photon Mono]] | Photon Mono (small)|Photon Mono (small)|
 +| [[tool:3d-printers:AnyCubic Photon Mono X | Mono X (medium)]] | Mono X (medium) |
 +| [[tool:3d-printers:AnyCubic Photon M3 Max | M3 Max (Large)]] | M3 Max (Large) |
Line 43: Line 47:
 | [[tool:vacuum_chamber|Vacuum Chamber]] | [[tutorials:fusion360|Fusion 360]] |  | [[tool:vacuum_chamber|Vacuum Chamber]] | [[tutorials:fusion360|Fusion 360]] |
 | [[tool:acrylic_bender|Acrylic Bender]] |  |  | [[tool:acrylic_bender|Acrylic Bender]] |  |
-| [[tool:injection_molder|Injection Molder]] |  |
 | [[tool:vacuum_investment_casting_machine|Vacuum Investment Casting Machine]] |  | | [[tool:vacuum_investment_casting_machine|Vacuum Investment Casting Machine]] |  |
Line 95: Line 98:
 ^ Machines ^ Supplies ^ misc ^ ^ Machines ^ Supplies ^ misc ^
 | [[tool:Industrial Arm]] | [[tool:officesupply|Office supplies]] | [[tool:admincabinet|Admin Cabinet]] | | [[tool:Industrial Arm]] | [[tool:officesupply|Office supplies]] | [[tool:admincabinet|Admin Cabinet]] |
-| [[tool:Mini-fridge]] | [[tool:labelingsupplies|Brother QL-570 Label Printer]] | [[tool:arcademachine|Arcade Machine]] |+| [[tool:Mini-fridge]] | [[tool:Keggerator]] | [[tool:labelingsupplies|Brother QL-570 Label Printer]] | [[tool:arcademachine|Arcade Machine]] |
 | [[tool:Chromecast|Chromecast TV and Speakers]] | [[tool:labelingsupplies#box of label strips|Labeling supplies]] | [[hacks:led_wall|LED Wall]] | | [[tool:Chromecast|Chromecast TV and Speakers]] | [[tool:labelingsupplies#box of label strips|Labeling supplies]] | [[hacks:led_wall|LED Wall]] |
 | [[tool:ultrasonic_cleaner|Ultrasonic Cleaner]] | [[tool:cleaning_supplies|Cleaning supplies]] | [[tool:social_buttons|VHS Social Buttons]] | | [[tool:ultrasonic_cleaner|Ultrasonic Cleaner]] | [[tool:cleaning_supplies|Cleaning supplies]] | [[tool:social_buttons|VHS Social Buttons]] |
Line 116: Line 119:
 ^ Machines ^ Supplies ^  ^ Machines ^ Supplies ^
-| [[tool:refrigerator]] | Beer? +| [[tool:refrigerator]] |
 | [[tool:coffee_machine|Coffee Machine]] | Cups | | [[tool:coffee_machine|Coffee Machine]] | Cups |
 | [[tool:hot plate]] | [[tool:Brewing Equipment]] | | [[tool:hot plate]] | [[tool:Brewing Equipment]] |
Line 129: Line 132:
 | [[tool:RedSail CM1080 Laser Cutter]] | [[area:material_storage|Laser cutter material storage]] |  | [[tool:RedSail CM1080 Laser Cutter]] | [[area:material_storage|Laser cutter material storage]] |
-| [[tool:laserfilter|Laser cutter filtration system]] | [[tool:laser_cutter:materials|Approved Laser Cutter Materials]] |+| [[tool:laserfilter|Laser cutter filtration system]] | [[tool:laser_cutter:settings|Approved Laser Cutter Materials]] |
-====== Metal Work ======+====== CNC Area======
-See: [[area:metal_shop|Metal Shop]], [[area:welding|Welding Zone]]+See: [[area:metal_shop|Machine Shop]]
 ^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^ ^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^
-| [[tool:Sherline CNC Mill]] | [[tool:Welder|Millermatic 211 MIG Welder]] | Hand Tools | Safety Equipment | +| [[tool:Sherline CNC Mill|Sherline]] | Shopvac (Shared with Machine Shop) | Hand Tools | Safety Equipment |
-| [[tool:Grizzly X3 4-Axis CNC Mill]] | [[tool:PowerTIG250EX|PowerTIG 250EX Welder]] | [[tool:Norseman Drill Bit Set]] | Flux | +| [[tool:Grizzly X3 4-Axis CNC Mill|CNC Mill "Gage"]] |  | CNC Tool Library (WIP) | Flux |
-| [[tool:manual_lathe|Metal Lathe]] | [[tool:Bosch 4.5" Angle Grinder]] |  | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] | +| CNC Mill "Jaxon" |  |  | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]]
-| [[tool:6040 CNC Mill]] | [[tool:Cut-Off Saw]] |  | Donated metal |+| [[tool:6040 CNC Mill|6040 CNC Mill "Laratron"]] |
 +| [[tool:Drill Press]] |
 +====== Machine Shop ======
 +^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^
 +| [[tool:Green Manual Mill]] | [[tool:Welder|Millermatic 211 MIG Welder]] | Hand Tools | Safety Equipment |
 +| [[tool:manual_lathe|Metal Lathe]] | [[tool:PowerTIG250EX|PowerTIG 250EX Welder]] | [[tool:Norseman Drill Bit Set]] | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] |
 +| [[tool:Bench Bandsaw]] | |
 +| [[tool:Horizontal Bandsaws]] | |
 +====== Metal Shop ======
 +See: [[area:welding|Metal Shop]]
 +| Box and Pan Brake | [[tool:Welder|Millermatic 211 MIG Welder]] | Hand Tools | Safety Equipment |
 +| Welding Table | [[tool:PowerTIG250EX|PowerTIG 250EX Welder]] | | Flux |
 +| [[tool:manual_lathe|Metal Lathe]] | [[tool:Bosch 4.5" Angle Grinder]] | | [[tool:fasteners|Nuts, Bolts, Screws, Washers...]] |
 +| [[tool:Bench Grinder]] | [[tool:Cut-Off Saw]] |  | Donated metal |
 | [[tool:Green Manual Mill]] | [[tool:18.0V Cordless Drill]] | | [[tool:Green Manual Mill]] | [[tool:18.0V Cordless Drill]] |
 | [[tool:Bench Bandsaw]] | [[tool:Plasma Cutter]] | | [[tool:Bench Bandsaw]] | [[tool:Plasma Cutter]] |
 | [[tool:Horizontal Bandsaws]] | [[tool:Ring Roller]] | | [[tool:Horizontal Bandsaws]] | [[tool:Ring Roller]] |
-| [[tool:Bench Grinder]] |
 | [[tool:Scroll Saw]] | | [[tool:Scroll Saw]] |
 | [[tool:Buffing Machine]] | | [[tool:Buffing Machine]] |
Line 151: Line 178:
 | [[tool:Blacksmith forge and anvil]] | | [[tool:Blacksmith forge and anvil]] |
 | [[tool:Heat Treating Oven]] | | [[tool:Heat Treating Oven]] |
Line 167: Line 193:
 | [[tool:Mini Wood (Pen) Lathe]] | [[tool:Planer 40200H]] | | [[tool:Mini Wood (Pen) Lathe]] | [[tool:Planer 40200H]] |
 | [[tool:Small Wood Lathe]] | [[tool:7-1/4-inch Circular Saw]] |   | [[tool:Small Wood Lathe]] | [[tool:7-1/4-inch Circular Saw]] |
-| [[tool:Barry the 14" Bandsaw]] |  |
 | [[tool:Bernie the Spindle Sander]] |  | | [[tool:Bernie the Spindle Sander]] |  |
 | [[tool:Bosch Miter Saw]] |  | | [[tool:Bosch Miter Saw]] |  |
 | [[tool:Hammer Jointer/Planer]] |  | | [[tool:Hammer Jointer/Planer]] |  |
-| [[tool:Air Compressor]] |  |
-| [[tool:Ace A-27 2HP Dust Extractor]] | [[tool:Delta Dust Extractor]]  |
-| [[tool:Ridgid 16 Gallon Shop Vacuum]] | [[tool:Ridgid 4 Gallon Portable Vacuum]] |
-| [[tool:Dremel Vibrating Multi Tool]] |  |
-===== Maintenance/Facility =====+| [[tool:Ridgid 4 Gallon Portable Vacuum]] |  |
 +| [[tool:Magnum Industrial Dust Collector]] | [[tool:Dremel Vibrating Multi Tool]]  |
-^ Machines ^ Supplies ^  +====== Maintenance/Facility ======
-| [[hacks:wades|Woodshop Automatic Dust Extraction System (WADES)]] | machine oil |+
 +^ Machines ^
 +| [[tool:woodshop_dust_extraction_automation_system|Woodshop Dust Extraction Automation System]] |
 | [[tool:powertec_air_filter|POWERTEC AF1044 3SPD Air Filtration System]] | | [[tool:powertec_air_filter|POWERTEC AF1044 3SPD Air Filtration System]] |
-| [[tool:transformer|20kVA Transformer]] |+| [[tool:transformer|Power Transformer 20kVA 240V Delta to 120/208V Wye ]] |
 +| [[tool:Air Compressor|Campbell Hausfeld Air Compressor (tank is still in use)]] |
 +| [[tools:Boge Air Compressor|Boge Air Compressor]] |
 ====== Retirement ====== ====== Retirement ======
 [[area:Retirement|Candidates for Retirement]] \\ [[area:Retirement|Candidates for Retirement]] \\
 [[area:Retired Equipment]] [[area:Retired Equipment]]
tool.1645471524.txt.gz · Last modified: 2022/02/21 19:25 by rob
