tool [2022/01/18 06:41] – mike | tool [2024/10/27 15:48] (current) – johnc | ||
Line 19: | Line 18: | ||
====== 3D Printing Area ====== | ====== 3D Printing Area ====== | ||
- | | [[tool:DittoPro|Tinkerine Ditto Pro]] | [[tool: | + | | [[tool:voron_v2.4_voltron|Voron v2.4 350mm: Voltron]] | [[tool: |
| [[tool: | | [[tool: | ||
- | | [[tool:Prusai3B|Prusa i3 without case]] | [[tool: | + | | [[tool:DittoPro|Tinkerine Ditto Pro]] | [[tool: |
Line 34: | Line 33: | ||
+ | ^ SLA Printers (Resin) ^ Model ^ | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
Line 43: | Line 47: | ||
- | | [[tool: | ||
Line 84: | Line 87: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | |.[[tool: | ||
Line 93: | Line 98: | ||
Line 114: | Line 119: | ||
Line 127: | Line 132: | ||
^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^ | ^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^ | ||
- | | [[tool:Grizzly X3 4-Axis CNC Mill]] | [[tool: | + | | [[tool: |
- | | [[tool: | + | | CNC Mill " |
- | | [[tool:6040 CNC Mill]] | [[tool: | + | | [[tool:6040 CNC Mill|6040 CNC Mill " |
+ | | [[tool: | ||
+ | ====== Machine Shop ====== | ||
+ | See: [[area: | ||
+ | | [[tool: | ||
+ | | [[tool:manual_lathe|Metal Lathe]] | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | ====== Metal Shop ====== | ||
+ | | [[tool: | ||
+ | | [[tool:Bench Grinder]] | [[tool: | ||
- | | [[tool: | ||
Line 149: | Line 178: | ||
| [[tool:Heat Treating Oven]] | | | [[tool:Heat Treating Oven]] | | ||
Line 161: | Line 189: | ||
| [[tool:Mini Wood (Pen) Lathe]] | [[tool: | | [[tool:Mini Wood (Pen) Lathe]] | [[tool: | ||
- | | [[tool: | ||
- | | [[tool:Air Compressor]] | | | ||
- | | [[tool:Ace A-27 2HP Dust Extractor]] | [[tool: | ||
- | | [[tool: | ||
- | | [[tool: | ||
- | ===== Maintenance ===== | + | | [[tool: |
+ | | [[tool: | ||
- | ^ Machines | + | ====== Maintenance/ |
- | | [[hacks:wades|Woodshop | + | |
+ | ^ Machines ^ | ||
+ | | [[tool:woodshop_dust_extraction_automation_system|Woodshop Dust Extraction | ||
+ | | [[tool: | ||
+ | | [[tool:Air Compressor|Campbell Hausfeld Air Compressor (tank is still in use)]] | | ||
+ | | [[tools: | ||
====== Retirement ====== | ====== Retirement ====== | ||
[[area: | [[area: | ||
tool.1642488106.txt.gz · Last modified: 2022/01/18 06:41 by mike
