tool [2019/04/08 19:57] – 00739 | tool [2024/10/27 15:48] (current) – johnc | ||
Line 17: | Line 16: | ||
- | ====== 3D Printing ====== | + | ====== 3D Printing |
- | | [[tool:DittoPro|Tinkerine Ditto Pro]] | 3D Printing | + | | [[tool:voron_v2.4_voltron|Voron v2.4 350mm: Voltron]] | [[tool: |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
- | ===== Casting ===== | + | ^ Loaner 3D printers ^ Model ^ |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
- | ^ Tools | + | ^ SLA Printers (Resin) ^ Model ^ |
+ | | [[tool: | ||
+ | ====== Paint & Mess Room ====== | ||
+ | ^ Tools | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
| [[tool: | | [[tool: | ||
- | | [[tool:injection_molder|Injection Molder]] | | | + | | [[tool:vacuum_investment_casting_machine|Vacuum Investment Casting Machine]] | | |
===== Sewing ===== | ===== Sewing ===== | ||
^ Machines ^ Tools ^ Supplies | ^ Machines ^ Tools ^ Supplies | ||
+ | | [[tool: | ||
===== Art ===== | ===== Art ===== | ||
- | ^ Machine ^ Tools ^ Supplies ^ | + | ^ Machine ^ Tools ^ Supplies |
- | | | Paint and sponge brushes | Paint (watercolour, | + | | | Paint and sponge brushes | Paint (watercolour, |
- | + | | | Exacto Knife kit | Ribbons | |
- | Stamps, Stamp ink pads, balsa wood, sidewalk chalk, pencil | + | |
Line 61: | Line 76: | ||
====== Electronics ====== | ====== Electronics ====== | ||
- | See: [[area:crafting|Crafting | + | See: [[area:electronics|Electronics |
^ Soldering Equipment | ^ Soldering Equipment | ||
- | | [[tool:Hot Air Station]] | [[tool: | + | | [[tool:Hot Air Station]] | [[tool: |
- | | [[tool:SMD Reflow Oven]] | [[tool: | + | | [[tool:SMD Reflow Oven]] | [[tool: |
- | | | [[tool: | + | | [[tool: |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | |.[[tool: | ||
====== The Hangout ====== | ====== The Hangout ====== | ||
+ | | [[tool: | ||
===== Ops Room ===== | ===== Ops Room ===== | ||
Line 101: | Line 119: | ||
+ | | [[tool: | ||
Line 112: | Line 131: | ||
- | | Laser cutter filtration system | | | + | | [[tool: |
- | ^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies | + | ^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^ |
- | | [[tool: | + | | CNC Mill " |
- | | [[tool:Drill Press]] | [[tool: | + | | [[tool:6040 CNC Mill|6040 CNC Mill " |
- | | [[tool:Green Manual Mill]] | [[tool: | + | | [[tool: |
- | | [[tool: | + | ----- |
- | | [[tool:Bench Grinder]] | | + | |
+ | ====== Machine Shop ====== | ||
+ | See: [[area: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool:Bench Bandsaw]] | | | ||
+ | | [[tool: | ||
+ | ====== Metal Shop ====== | ||
+ | | [[tool: | ||
+ | | [[tool:Bench Grinder]] | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool:Heat Treating Oven]] | | ||
Line 137: | Line 183: | ||
====== Woodworking ====== | ====== Woodworking ====== | ||
- | See: [[area:Woodworking|Woodwork Area]] | + | See: [[area:Wood_shop|Wood Shop]] |
- | | [[tool:Wood CNC]] | [[tool: | + | | [[tool:Wood CNC]] | [[tool: |
- | | [[tool:Bench Bandsaw]] | [[tool:Random-Orbit Palm Sander]] | | + | | [[tool:Bench Bandsaw]] | [[tool:18.0V Cordless Drill]] | [[tool:Norseman Drill Bit Set]] | | |
- | | [[tool:Mini Wood (Pen) Lathe]] | [[tool:Cut-Off Saw]] | | + | | [[tool:Mini Wood (Pen) Lathe]] | [[tool:Planer 40200H]] | |
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | ====== Maintenance/ | ||
+ | ^ Machines ^ | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool: | ||
+ | | [[tool:Air Compressor|Campbell Hausfeld Air Compressor (tank is still in use)]] | | ||
+ | | [[tools: | ||
====== Retirement ====== | ====== Retirement ====== | ||
[[area: | [[area: | ||
tool.1554753466.txt.gz · Last modified: 2019/04/08 19:57 by 00739
