tool:video_wall
tool:video_wall [2020/03/07 00:59] – dbynoe | tool:video_wall [2024/05/18 03:26] (current) – dbynoe | ||
Line 8: | Line 8: | ||
^ | Hardware - Probably not a good idea| | ^ | Hardware - Probably not a good idea| | ||
- | ^ |Firmware on the FPGA's (sender and reciever cards) - Very not advised unless you know what you are doing | | + | ^ |Firmware on the FPGA's (sender and reciever cards) - Very not advised unless you know what you are doing password at bottom section of this page | |
^ Usage Restrictions | None| | ^ Usage Restrictions | None| | ||
^ Owner | VHS| | ^ Owner | VHS| | ||
Line 26: | Line 26: | ||
+ | ==== Quick facts ==== | ||
+ | * 256x224 resolution | ||
+ | * runs windows | ||
+ | * acts like a giant external monitor by mirroring a portion of the video stream | ||
+ | * its awesome. | ||
Line 79: | Line 84: | ||
* Can be mounted sideways | * Can be mounted sideways | ||
* has 3 - 80 amp 5v power supplies | * has 3 - 80 amp 5v power supplies | ||
- | * draws between 1 and 8 amps of 120v ac at full white depending on brightness level. | + | * draws between 1 and 8 amps of 120v ac at full white depending on brightness level. |
+ | * LED Wall Features 4 of these. | ||
+ | ==== Setting password ==== | ||
+ | DO YOU NEED THE PASSWORD FOR THE PARA SETTINGS? | ||
+ | READ THIS FIRST!!!! | ||
+ | YOU CAN DESTROY THIS DEVICE WITH THE WRONG SETTINGS | ||
+ | THIS IS NOT A JOKE | ||
+ | Rule 1. DO NOT CHANGE ANYTHING ON THE RIGHT SIDE OF THE PROGRAM ESPECIALLY SCREEN OPTIONS AND RECIEVER CARD AREAS | ||
+ | which we do not have a backup for THEY ARE UNRECOVERABLE. | ||
+ | I spent over a month trying to recreate them using a spare reciever card | ||
+ | It did not work, DO NOT ATTEMPT TO FIGURE IT OUT WITHOUT FIRST TALKING TO @dbynoe, there is no recovery possible, YOU WILL DESTROY THE DISPLAY, no take backsies. I spent a lot of time to build this, a ton of hours figuring out how to make it work, and a bunch of hours, donated a decent chunk of cash to buy the sender card. DONT FUCK IT UP. thank you. | ||
+ | Rule 6. Limit brightness to below 20%, 100% will draw up to 30amps. | ||
+ | Rule 8: note that that you have been made aware of a very limited subset of the potential hazards contact @dbynoe on talk/slack if you really want to play with this. | ||
+ | Rule 10: the password is the numbers of the above rules in order, only change settings under screen display (brightness, | ||
tool/video_wall.1583542798.txt.gz · Last modified: 2020/03/07 00:59 by dbynoe
