tool:thickness_sander
tool:thickness_sander [2016/11/25 17:59] – Added tool name. mike | tool:thickness_sander [2023/02/02 15:34] (current) – phillip_ma | ||
- | {{::generic-tool.png?200 |}} | + | {{::thicknessSander.jpg?200 |}} |
- | Summary description of the tool and perhaps some misc notes about it's existence! | ||
- | ^ Status | + | == CURRENTLY OFFLINE == |
- | ^ Training | + | |
- | ^ Hackable | + | Similar in use to a thickness planer, a thickness sander allows you to achieve a consistent thickness |
- | ^ Usage Restrictions | Members | + | across the length of a piece of wood. |
- | ^ Owner | Michael Kessler | + | |
- | ^ If it Breaks | + | ^ Status |
+ | ^ Brand | Delta | ||
+ | ^ Usage Restrictions | Members | ||
+ | ^ Owner | Michael Kessler | ||
- | ^ Arrival Date | + | ^ Arrival Date |
^ Location | ^ Location | ||
- | ^ Value | $150 | | + | ^ Value | $$$ |
+ | * Update this wiki to help with onboarding usage. | ||
+ | ** WOOD ONLY ** | ||
+ | No metal, not even once! | ||
The thickness sander is a rotating power tool that can generate large quantities of wood dust. | The thickness sander is a rotating power tool that can generate large quantities of wood dust. | ||
Line 23: | Line 37: | ||
Eye protection, Breathing Protection, Environmental Dust Collection, Ear Protection, Skin Protection, | Eye protection, Breathing Protection, Environmental Dust Collection, Ear Protection, Skin Protection, | ||
No baggy/ | No baggy/ | ||
+ | Use push-sticks and take care for kickback. | ||
Take special care not to raise the bed into the sanding drum, which will cause permanent damage. | Take special care not to raise the bed into the sanding drum, which will cause permanent damage. | ||
Line 28: | Line 44: | ||
Line 34: | Line 50: | ||
- | ===== Maintenance Log ==== | + | Some tips: |
+ | * Start with a pass where you aren't sanding anything so that you know you aren't cutting too deep and progress it no more than a 16th of a turn. | ||
+ | ===== Manual ===== | ||
- | ^ Note | + | ^ Note ^ Date ^ Who ^ |
- | | Wiki entry created | Nov 25, 2016 | Michael K. | | + | | Wiki entry created |
+ | | Dismandled | ||
+ | | Replaced with Delta | 2018 | Michael K. | | ||
+ | | Out of service for repair | 6 Jan, 2021 | Michael K. | | ||
+ | | Planned Removal | 30 Aug, 2021 | Michael K. | | ||
+ | | Planer Tuneup and trainers trained (phillip_m and yeungx) | January 2022 | Phillip M | | ||
+ | | Drive belt for sanding Drum replaced since it broke, Beveled gears controlling lift mechanism replaced with steel gears. | ||
+ | | Motor for the conveyor belt repaired. | ||
+ | | Motor for the conveyor belt seized again shortly after it was reinstalled. | ||
tool/thickness_sander.1480096782.txt.gz · Last modified: 2016/11/25 17:59 by mike
