tool:sewing_machines [2021/10/12 05:21] meghan_haltontool:sewing_machines [2024/09/22 20:56] (current) elizabot
Line 7: Line 7:
 **Sewing Machine FAQ:** **Sewing Machine FAQ:**
 +  * // **Important note**// Please make sure that you have the needle all the way up before you remove the fabric. If the fabric doesn't pull out easily, move the handwheel a bit until it does.
 +  * // **Important note**// Not all feet work on all sewing machines!
   * //**My stitches are uneven / keep skipping**// - Check what kind of needle is in the machine. [[sewing_needles|Different needles are for different fabric.]] If your needle is [[sewing_needles#Ballpoint_Needle|dull**]], crooked or snagging your fabric, change it   * //**My stitches are uneven / keep skipping**// - Check what kind of needle is in the machine. [[sewing_needles|Different needles are for different fabric.]] If your needle is [[sewing_needles#Ballpoint_Needle|dull**]], crooked or snagging your fabric, change it
-  * //**It keeps jamming from the bottom**// - [[tool:sewing_needles#Types_of_bobbins|Are you using the correct bobbin for the machine?]] Check that your bobbin is wound correctly and inserted in the right direction +  * //**It keeps jamming from the bottom**// - [[tool:sewing_needles#Types_of_bobbins|Are you using the correct bobbin for the machine?]] Check that your bobbin is wound correctly and inserted in the right direction. Note: the Janome and the Brother should only be used with plastic bobbins, not metal.
-  * //**I'm sewing but all my stitches fall out**// - Did you run out of bobbin thread? Wind a new bobbin. Did you leave the presserfoot up? You can only sew with it in the down position first.+  * //**I'm sewing but all my stitches fall out**// - Did you run out of bobbin thread? Wind a new bobbin. Did you leave the presser foot up? You can only sew with it in the down position first.
   * //**Threads are too loose or pulling tight**// - Check that your machine is threaded correctly. Check the tension dials and stitch length.   * //**Threads are too loose or pulling tight**// - Check that your machine is threaded correctly. Check the tension dials and stitch length.
-  * //**I'm sewing but it won't go anywhere**// - Check your stitch length and style, are you on a stretch stitch or fancy? Are you trying to sew with the presserfoot up?+  * //**I'm sewing but it won't go anywhere**// - Check your stitch length and style, are you on a stretch stitch or fancy? Are you trying to sew with the presser foot up?
 ===== Brother Innov-ís 80 ===== ===== Brother Innov-ís 80 =====
Line 18: Line 20:
  {{ :tool:brotherinnovis80.jpg?direct&400|}}  {{ :tool:brotherinnovis80.jpg?direct&400|}}
-^ Status             Broken October 2021 - Bobbin shuttle sewn through, repeatedly! Part XC3152221 on order, to arrive October 15th 2021                           +^ Status             Working (May 2023)
-^ Training           Recommended                                     |+^ Training           Not needed, but ask Liz if you want assistance|
 ^ Hackable           | NO                                                              | ^ Hackable           | NO                                                              |
 ^ Usage Restrictions | Anyone                     | ^ Usage Restrictions | Anyone                     |
 ^ Owner              | VHS                                        | ^ Owner              | VHS                                        |
 ^ If it Breaks       | It's probably not truly broken, you just jammed the thread or broke a needle. 1) replace your needle and re-thread the machine 2) If that doesnt work, put a sticky note on it and contact a champion   | ^ If it Breaks       | It's probably not truly broken, you just jammed the thread or broke a needle. 1) replace your needle and re-thread the machine 2) If that doesnt work, put a sticky note on it and contact a champion   |
-^ Loan Status        | Unknown                | +^ Loan Status        | Donated by rsim - contact if removal required                |
-^ Location           | On the sewing table                             |+^ Location           | On or under the sewing table                             |
 ^ Value              | $$        | ^ Value              | $$        |
Line 38: Line 40:
 {{ :tool:janome6019.jpg?direct&400|}} {{ :tool:janome6019.jpg?direct&400|}}
-^ Status             Bobbin thread was not working as of May 2021                         +^ Status             Repaired by Euro-Tech in May 2023, there's a 1-year warranty.
-^ Training           Recommended                                     |+^ Training           Not needed, but ask Liz if you want assistance |
Line 45: Line 47:
 ^ Loan Status        | Unknown    (has a label saying on loan from Miststlkr)             | ^ Loan Status        | Unknown    (has a label saying on loan from Miststlkr)             |
-^ Location           Sewing table                                  |+^ Location           On or under the sewing table                              |
Line 52: Line 54:
   * [[http://janome.com/siteassets/support/manuals/retired/other-models/inst-book-6019qc.pdf|Instruction Manual PDF]]   * [[http://janome.com/siteassets/support/manuals/retired/other-models/inst-book-6019qc.pdf|Instruction Manual PDF]]
   * [[https://www.youtube.com/watch?v=7W2WJhoMtJI]]   * [[https://www.youtube.com/watch?v=7W2WJhoMtJI]]
- +  * Repair receipt with warranty: {{:tool:janome_repair_receipt_with_warranty.jpeg?200|}}
-===== Kenmore Ultrastitch 12 ===== +
-{{ :tool:kenmoreus12.jpg?direct&400|}} +
-^ Status             | Status unknown (needs testing)                      | +
-^ Training           | Recommended                                     | +
-^ Hackable           | NO                                                              | +
-^ Usage Restrictions | Anyone                     | +
-^ Owner              | VHS                                        | +
-^ If it Breaks       | It's probably not truly broken, you just jammed the thread or broke a needle. 1) replace your needle and re-thread the machine 2) If that doesnt work, put a sticky note on it and contact a champion   | +
-^ Loan Status        | Unknown  (has a label saying loaned by Davonna)              | +
-^ Location           | Under the side crafting table                                     | +
-^ Value              | $        | +
-^ Champion           | See [[tool:compendium_of_champions#tools|Compendium of Champions]]     |+
 ===== Kenmore Ultrastitch 6 ===== ===== Kenmore Ultrastitch 6 =====
-{{ :tool:kenmoreus12.jpg?direct&400|}} +{{ :tool:KenmoreUltrastitch6.jpg?direct&400|}}
-^ Status             | Operational & tension set October 2021                      |+^ Status             | Operational as of January 2023                     |
 ^ Training           | Recommended                                     | ^ Training           | Recommended                                     |
Line 79: Line 67:
 ^ Loan Status        | Unknown                  | ^ Loan Status        | Unknown                  |
-^ Location           Under the sewing table                                  | +^ Location           On or under the sewing table                              |
-^ Value              | $        | +
-^ Champion           | See [[tool:compendium_of_champions#tools|Compendium of Champions]]     | +
-===== Singer 656G ===== +
-  * Type: Slant Shank Sewing Machine +
-  * Manual: Not found, but possibly hard copy available at the space +
-  {{ :tool:singer658g.jpg?direct&400|}} +
-^ Status             | Whereabouts unknown                         | +
-^ Owner              | VHS                                        | +
-^ Loan Status        | (Unknown, Owned, Permanent, Temporary, Semi-Permanent                  | +
-^ Location           | Blue rubbermaid bin under the desk beside crafting table                        |+
 ^ Value              | $        | ^ Value              | $        |
Line 103: Line 75:
 {{ :tool:singerstylist478.jpg?direct&400|}} {{ :tool:singerstylist478.jpg?direct&400|}}
-^ Status             Whereabouts unknown                    |+^ Status             Janet took this home to fix (May 2023)              |
Line 110: Line 82:
 ^ Loan Status        | (Unknown, Owned, Permanent, Temporary, Semi-Permanent                  | ^ Loan Status        | (Unknown, Owned, Permanent, Temporary, Semi-Permanent                  |
-^ Location           Blue rubbermaid bin under the desk beside crafting table                 |+^ Location           Under the sewing table                 |
Line 116: Line 88:
 ====== VHS Sergers ====== ====== VHS Sergers ======
-===== Kenmore 3/4 Differential Feed =====+===== Janome MyLock 234D =====
-This is the main serger set up on the craft table. By default it is set at a 4-thread safety stitch for general purpose woven and stretch fabrics. Feel free to change thread cone colours, but for 3-thread edging, use the Janome located on the workbench.+{{ :tool:janomemylock.jpg?direct&400|}}
-{{ :tool:kenmore34serger.jpg?direct&400|}} +^ Status             Operational as of January 2023
-^ Status             Unknown (needs testing)                           +^ Training           We don't have any training for Sergers unfortunately, but you can ask Liz or Metal Janet to help you figure it out. |
 ^ If it Breaks       | Check your lower looper threads if they are threaded properly. Check needles. \\ [[tool:sewing_needles#Serger_Needles|DO NOT PUT SEWING MACHINE NEEDLEs IN THE SERGER]] \\ If that doesnt work, put a sticky note on it and contact a champion   | ^ If it Breaks       | Check your lower looper threads if they are threaded properly. Check needles. \\ [[tool:sewing_needles#Serger_Needles|DO NOT PUT SEWING MACHINE NEEDLEs IN THE SERGER]] \\ If that doesnt work, put a sticky note on it and contact a champion   |
-^ Loan Status        | (Unknown, Owned, Permanent, Temporary, Semi-Permanent                  +^ Loan Status        | Donated by Miststlkr Contact for pickup
-^ Location           Main crafting table                                     |+^ Location           Desk beside main crafting table                                     |
-===== Janome MyLock 234D =====+[[http://janome.com/siteassets/support/manuals/retired/serger/inst-book-234-en.pdf| Manual PDF]]
-VHS' other serger, this machine is by default set to a 3-thread overlock to finish edges but not sew pieces together. Feel free to change thread cone colour.+====== VHS Embroidery Machine ======
-{{ :tool:janomemylock.jpg?direct&400|}}+===== Brother PE 800  =====
-^ Status             Unknown (needs testing)                        +{{:tool:embroidery_machine_brother_pe800.jpg?400|}}
 +^ Status             Operational as of September 2024
 +^ Training           Talk to Liz |
-^ If it Breaks       Check your lower looper threads if they are threaded properly. Check needles. \\ [[tool:sewing_needles#Serger_Needles|DO NOT PUT SEWING MACHINE NEEDLEs IN THE SERGER]] \\ If that doesnt work, put a sticky note on it and contact a champion   +^ If it Breaks       Put a sticky note on it and contact a champion |
-^ Loan Status        | Donated by Miststlkr - Contact for pickup                 +^ Loan Status        | This was a group buy by VHS members
-^ Location           Desk beside main crafting table                                     +^ Location           On the sewing table
-^ Value              | $$        | +^ Value              | $$$        |
-^ Champion           | See [[tool:compendium_of_champions#tools|Compendium of Champions]]     |+^ Champion           | See [[tool:compendium_of_champions#tools|Compendium of Champions]]
 +There are spare needles and a USB drive inside the purple cover.
 +{{ :tool:brother_pe800_manual.pdf |}}
 +[[https://www.youtube.com/watch?v=DfpJXuBeEPM|Intro Video]]
-[[http://janome.com/siteassets/support/manuals/retired/serger/inst-book-234-en.pdf| Manual PDF]]
 ====== VHS Industrial Sewing Machines ====== ====== VHS Industrial Sewing Machines ======
-===== Reliable Sewing Machines 4000SW walking foot =====+===== Reliable Sewing Machines RELSEW GC0618-1 =====
 The don't mess around & will sew darn near anything industrial machine. It will happily sew leather, canvas, denim, and other thick materials.  The don't mess around & will sew darn near anything industrial machine. It will happily sew leather, canvas, denim, and other thick materials.
 For threading and other instructions see the detailed page on the [[tool:Relsew4000SW|Relsew 4000SW]] For threading and other instructions see the detailed page on the [[tool:Relsew4000SW|Relsew 4000SW]]
-{{ :tool:4000sw_spec.png?direct&400|}}+{{:tool:4000sw_spec.png?direct&400|}}
-^ Status             Tuned up and working September 5 2021 |+^ Status             Out of Order as of September 2024 (bobbin case is broken, we are getting a new one) |
-^ Usage Restrictions | Anyone with experience on domestic machines |+^ Usage Restrictions | Anyone with experience on domestic machines - watch your fingers! |
 ^ Owner              | David Bynoe| ^ Owner              | David Bynoe|
 ^ If it Breaks       | Contact David - @dbynoe on slack and talk | ^ If it Breaks       | Contact David - @dbynoe on slack and talk |
Line 170: Line 148:
-[[https://cdn.shopify.com/s/files/1/1267/1415/files/4000SW_Manual_Nov26.pdf?6347539493848786786| Manual PDF]]+There is a threading guide on the wall behind the machine.
 +[[https://vanhack.ca/lib/exe/fetch.php?media=relsew-industrial-sewing-machine-manual.pdf| Manual PDF]]
 Additional info from dbynoe:  Additional info from dbynoe:
tool/sewing_machines.1634016068.txt.gz · Last modified: 2021/10/12 05:21 by meghan_halton
